Question about Jenn-Air JMV8196 Microwave Oven
Microwave totally shuts off by itself
I have jenn-air JMV 8208BAS over the range microvawe. I set up kitchen timer for 60 min. after 30 min. microwave shut of completely. I noticed microvawe was hot inside. I plugged out from electrical line and plugged in again. But did not help
Thanks Mila
  • Macademic Aug 03, 2008
    My microwave was built in 2005. It is used only occasionally. We noticed an electrical smell and then the unit stopped heating food. Now when turned on it makes a loud noise and appears to operate normally but still fails to heat food.
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Posted on Jun 30, 2008
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
Husband thought he set the timer but actually ran the over for 35 min. This was really hot and now looks dead. No displays, nothing.
Yes, you are probably right... he killed it... :-(
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 16, 2010 | Jenn-Air JMV8208AAS Microwave Oven
No power at display!
You've probably destroyed your magnetron, and the magnetron thermostat.
This kind of abuse will not be covered under warranty.
It will likely run about $75 for a technician to visit the home, $75 to do the work, $75-90 for the magnetron, and about $15 for the thermostat.
You can locate a Maytag-authorized servicer at http://www.maytag.com
Apr 24, 2010 | Maytag MMV4205 Microwave Oven
A blue arc came out of my jen air , jmv 8208bas,microwave oven and now the motor keeps running unless the door is left open. The light is out now too. what is the fix for this problem. could you tell me...
I would suspect that your main relay on the control board is shorted.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This failure often occurs when a cooktop bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You might consider checking your door switches when you remove the controller. See this file.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 09, 2010 | Microwave Ovens
No power in the microwave. It is as if you unplugged it. Is there an internal fuse in the unit? There is power to the unit. The unit shows nothing on the panel and when you open the door, no light comes...
If you look at the back of the oven there are usually small fuses or breakers back there. Check to see if that is the issue. Also if you haven't already make sure the wall outlet is functional.
Dec 14, 2009 | Jenn-Air JMC7000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMV8196 Microwave Oven Logo
114 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
