Question about Vizio L37 Television
Remote controls don't work
In the middle of the afternoon yesterday all of my remote controls stopped working at the same time controlling different devices. The remote for my directv reciever, my stero, my dvd player, and even the default tv set remote all fail to work. It seems like there must be some sort of interfernce but I can't think of what it could be. I can turn on all of the devices by hand but once again the remotes collectively do nothing. Any help diagnoising or what I can do would be greatkt appreciated.
  • 2 more comments
  • familyvalues Jul 26, 2008
    vx37L
    Just started happening to me to, randomly all my remotes dont work with the tv anymore, tivo, stock remote etc. Unless I am 1 inch away, then it will work, but no farther! My dish washer is running? Seams odd. it is a refurb model.
  • arsenav Sep 13, 2008
    Yesterday all of my remote controls stopped working at the same time controlling different devices. The remote for my directv reciever, my stero, my dvd player, and even the default tv set remote all fail to work. It seems like there must be some sort of interfernce but I can't think of what it could be. I can turn on all of the devices by hand but once again the remotes collectively do nothing. Any help diagnoising or what I can do would be greatkt appreciated.
  • Anonymous Oct 24, 2008
    happens all the time!!
  • Anonymous Dec 07, 2008
    no matter what remote we use, it will not operate the tv, however, the remote operates the cable box and dvd
Funny fix....
Problem was my dvd remote had something sitting on it causing it to shoot a solid signal stream out, once i figured that out and removed the object from the dvd remote, everything was perfect. Freaked me out though but an easy fix.
Posted on Oct 05, 2008
Funny this happened. Mine did the same thing and the next day the screen starting going out. Vizio VX32L
I have the exactly same problem. Please help
Posted on Aug 22, 2008
How do I fix my Wii remote?
Controller is probably broken -- Use a different controller.
Jan 14, 2013 | Nintendo Wii Remote Controller
CEILING FAN WORKS,BUT REMOTE ONLY WORKS THE FAN SECTION, WILL NOT DIM LIGHTS NOR TURN OFF LIGHTS ONLY SO WE CAN USE FAN ONLY. WHAT DO WE HAVE TO DO?
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
Freesat remote control manual 02sd
Good morning, afternoon, evening or night; whatever time of day you are viewing this. Thank you for choosing FixYa to solve your request. You want the owner's manual for Freesat 02SD Remote Control? I don't know if this is really gonna help you out, but here's the owner's manual for the Bush BFSAT01SD Freesat Receiver. In this manual, you will see a diagram of the remote and what each button is for.
http://docs.google.com/viewer?a=v&q=cache:MIwevx2mn3IJ:freesatsupport.co.uk/skin/frontend/default/fscom/manuals/BFSAT01SDum.pdf+freesat+remote+control+manual&hl=en&gl=us&pid=bl&srcid=ADGEESicRZoFlcwVLvP-Oeb2fMh_dqRXt6nr_uIZ5nbk844QWOJOuoMXDxq19FlJcFyxsliaOTe32_CV2oeGH3vsz65nnwp5jxl4Ngbp-suWDjIqX4Z5qBTnNz_vuFoHTni8hVJqdRzz&sig=AHIEtbQ_u5VU1ot5G1QramI7VxYPHuc4Pg.
I know this isn't for the exact model you requested, but this is the closest model to that. Sorry for any inconvenience this may cause, but I hope this will work out for you in the end. Thank you for visiting this website and choosing us as your one-stop solution spot for assistance with electronic product problems and requests. Visit us again soon and have a good day, evening or night; whatever time of day you are viewing this.
May 16, 2011 | Audio Players & Recorders
My remote stopped working can it be reset
Hello;
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
Antenna button not functioning on RCA300x universal remote
U have glitches in the reprograming back and forth.Take the battery out,about an hour.Reprograms the codes again,should work again.Don't reprograms the codes back and forth to many times or one times to many will kill the remote for good.U have 2 tvs,U should have 2 tvs remotes.
Jun 22, 2010 | RCA RCU300 Remote Control
My remote control stopped working
try with simple test. with any camera (mobile) check for any light (infrared light is not visible, only cameras see the infrared light) in front remote control, while press a key, if a flashing light deteted the remote control is ok, and the problem maybe on remote function is selected, normaly using tv and select VCR or AUX, may occur this problem. or a defective receiver sensor.
Jan 02, 2010 | Televison & Video
Remote controlled ceiling fans stopped working
My guess is that a neighbor close by, got a similar fan. This is common I understand. Other than that.....I can not think of a single thing! I say that even after 30+ years of working with electrical, and electronics.
Oct 02, 2008 | Oasis Hunter 54' Ceiling Fan
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Vizio L37 Television Logo
212 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
