FixYa.com
Tags:
Whirlpool Calypso GVW9959K Top Load Washer
Calypso won't move into the Spin cycle, LD and OB... (by 3 users)
posted by kimjohnson on Jun 29, 2008
I hate this stupid washer. It won't go into the spin cycle and keeps running through the rinse cycle. After some time it gets either LD or OB errors. I've checked the pump and hoses and there is nothing in them that is clogging it. Any other ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by muggrn, posted on Jul 13, 2008
Mine does the same maddness...won't drain, won't spin, LD & OB errors, now is giving me FL error and keeps beeping, manual says it will do this until it drains...Right! Have followed every step the user manual suggests but really it seems that things are going from bad to worse. So now it sits with this nasty water in the tub and the next problem will be that it rusts or something. This is THE ABSOLUTE WORST machine I have ever owned. I can't even give it away!
Comment by Guest, posted on Jul 05, 2008
I have had the same problem off and on since I purchased the same washer in Dec. "03" Then one day about 7-8 months ago, my washer once again started to go into the drain and then spin cycle when it just beeped then stopped, then after a few minutes turned off. No errors codes. Nothing. I checked the the water pump, belt, hoses, cleaned out filter and drain box, you name it, even ran diagnostics on the control panel and was unable to get any error codes, just that there was an issue with the spin cycle. Whirlpool is USELESS always has been. So I have been going to the Laundromat once a week ever since.
Can you Help with these Washing Machines problems?
cabrio whirlpool washer
Code F - 51 keeps coming up.... Answer This...
C1 error code
I was washing a load of clothes... Answer This...
Stinky Washer
Every time we wash a load... Answer This...
Whirlpool Calypso
The washer gets to about 13... Answer This...
cl error
cl error comes on part way... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
