Question about Epson Stylus CX6600 All-In-One InkJet Printer
Have error with ink catridge, but I just want to scan.
I know the ink is out, but I would like to scan some photos, but the error light for ink will not allow me to do anything. is there some way to over ride that.
  • Epson Master
  • 691 Answers
I think you should be able to scan through your PC, but I'm not sure.
Best answer is just replace the cart it requires
Posted on Jun 30, 2008
Service error 6500 ix4000
The Canon website indicates that is a hardware problem, there's nothing i can do. You call a technician or the canon help support. This is the description of the code:
Other hardware error [6500] - Logic board ***'y (QM2-3393 / QM3-1654)
Mar 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Will not scan due to no colour ink. do not want to
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
MP 210 printer maintance is in progress code 21140
Try refilling them. If they are empty, there is no way you will be able to print anything (or scan, or copy).
Mar 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Cannon MP145, I want to only scan not printing.
There is no solution for that, if you want only scanning, you need a separate scanner. This machine will only scan when all other errors are taken care of. And all inks are full.
Sep 18, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Cartridge error 1203
It's mean your catridges overflow . Check to see if ink are smeared on the holder where the contact panel with the catridge.
1 ) Use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
2) The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
3) Print the test page to see how it's look and way you go.
4) Be sure not to leave any debris of klennex on those holder contact panel.
5) Make sure to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Sep 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
PIXMA MP610 can't scan without ink (makes no sense)
You can scan when out of ink. You have to press and hold the reset button (red triangle inside a circle) for five seconds which tells the printer to ignore ink problems and continue.
Jul 24, 2009 | Canon MP610 Photo All-In-One Printer
MP210 can't scan without catridge
it is not possible without cartridge because it is not only a scaner or printer it is a copier
Jul 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Don't know how to clean inkheads of my Epson Stylus Photo RX620
the ink only must not have tried up on the heads, it must have dried up completely what you should do is, the surface that faces down while inserting the catridge is the part you should clean or otherwise first shake the catridge very well untill ink comes out if ink does not come out, it means the ink has dried up, thanks
Jul 22, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Catridge problem
when printing try to press resume button for about 5 seconds
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark 5400 Printer does not use the photo cartridge
First of all as this Catridges are Non Intelligent they will not be able to show u the exact Ink level on the catridge then too if thats really happening this Solution below will fix it: In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the Photo on the left........ Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
