WINDOWS '98 SOFTWARE
HOW DO I FORMAT MY WINDOWS XP/PC TO PLAY WINDOWS '98 SOFTWARE?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Insert your win98 cd into the drive and set the booting option to boot from cd, with this enable start the computer with cd-rom support.here you will see
A:/
then type
A:/fdisk and press enter
here you will enbale partition follow the on-screen instruction then
A:/ format c:
after this:
locate your cd using
D;/
D:/win98
D:/setup
if yu follow this you will be able to load win98 on your PC.
Good luck
Posted on Jun 29, 2008
Windows 7 pc will not play cd made on older pc
You can tell any program in Windows 7 to run in Windows98 compatible mode. The standard format on windows2000 was fat32 Windows7 should run it but try to right click on the opening program and run it in 98 compatible mode. If not then XP mode Windows XP would run in either format fat32 or NTFS.
Apr 19, 2014 | Acer Computers & Internet
CANNOT PLAY BICYCLE PINOCHLE SINCE UPDATING COMPUTER PLAYED BICYCLE PINOCHLE ON WINDOWS 98, CANNOT PLAY ON WINDOWS 7
Unfortunately, due to changes in the OS and how programs run, a program written for Windows 98 will not run under Windows 7 directly.
Even the compatibility mode will probably not work unless your version of Bicycle Pinochle for Windows was written for XP as well as Windows 98. (The WinXP version would possibly run under the Windows 7 32-bit version; it won't work under the 64-bit OS. To find your version of Windows 7, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version.)
You need to either upgrade your game software or get an older version of Windows running somehow. This could be a virtual computer (runs inside your Windows 7 computer if your hardware permits it), a second machine or a dual boot computer. For Windows 98, you will need a licensed version of the OS for any method. Check a nearby Windows User's Group to see if anyone there has the OS.
If your version of Pinochle could run under Windows XP and you have Win7 Pro or Ultimate (or upgrade to them), you can run a virtual version of XP for free. In this case, download and install (in order) Virtual PC and XP mode from Microsoft. Then install the software in the XP computer as if it were the only computer running. (The compatibility mode didn't work inside XP mode for software written for Windows 2K so I doubt a Win98 program will work.)
An XP version of Bicycle Pinochle was offered by Microsoft: http://www.microsoft.com/games/bicycle/card/ . A Windows 7 version of Single Deck Pinochle is here: http://www.sac-irca.com/pino.html .
I wish that I had better news for you.
Oct 23, 2011 | Expert Software Bicycle Pinochle for...
By mistake formatted all Data including software
The software is only for Windows 98 otherwise the player is a plug and play device (Windows 2000, XP & Vista). Click here if your operating system is Windows 98.
Can you see the MP3 player on device manager?
Jul 28, 2009 | SanDisk Sansa m230 MP3 Player
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
I bought a 80 GB portable HDD but when I connect it to the computer running on Windows 98, the computer does not recognize the drive. Please advise what to do? The supplier did not provide any driver...
Win 98 does not support plug & Play USB devices unless the drivers are installed. Xp how ever does. you need to install the drivers to be able to used the device in win 98. since you did not get a driver cd, best would be to download the drive from the net. if you abl to give me more details of the device, i would be able to find the driver.
Mar 19, 2009 | Electronics - Others
Pendrive Problem in windows 98
you have to use xp os.because windows 98 is tatally back dated. thats why its not opening. or you can check it into another xp os. computer if it is open then your sure that windows 98 is not supporting, or if it is not open then your pendrive has some problem.
Mar 17, 2009 | Microsoft Windows 98 for PC
NEED HELP
if D drive was a partition on your hard drive it was very likely formatted ....
Robert
Sep 11, 2008 | Compaq Deskpro EN PC Desktop
DOWNLOAD DELL XP SOFTWARE ON TOP OF WINDOWS 98 NEED TO CORRECT THIS PROBLEM
If u have Windows Xp Cd just Boot from the CD and once when Partition Table comes at that time delete all the partition and create new partitions and select C : Drive and just format with NTFS or FAT File system Recommended is NTFS it will install Windows Xp on particular drive later once when windows is totaly up i.e, when desktop comes u just click on the other drives it will ask for Format just format it.
But the Problem u face is the drivers some drivers it will take automatically some it will not take at that time u should put u r machine model number and name in google and search
Sep 10, 2008 | Compaq Deskpro EN PC Desktop
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
