Question about InFocus ScreenPlay 4805 Multimedia Projector
Fan Replacement Cleaned Fan, Checked Voltage on Board. Everything is OK I am assuming fan needs replacement. 3108NL-04W-B50 12v DC 80mm And possibly 60mm as well Any idea where to order? Thanks!!
    Scholar:
  • 167 Answers
If the fan spins freely the problem is most likely not the fan but the 8 pin smd Mos-Fet fan speed control current amp has failed. Not difficult to replace and are a common problem with these projectors.
Posted on Nov 29, 2009
  • 2,237 Answers
If the voltage is ok for the 80mm (pn: 526-0192-xx) and the 60mm (pn: 526-0193-xx), replace them. you can get them from any infocus service center. try av solutions in ny. www.avsolutionsny.com. however, in order to replace them, you'll have to remove the top, front, and rear panels, remove the 2 power boards, the board shield, and the lamp housing. now you can unplug the fans and remove them. warning: be extremely careful around the colorwheel and the light tunnel (under the colorwheel). they are fragile and may fracture easily.
Posted on Dec 01, 2009
Does not goes to the recommanded temp.
If you have a 12 dc power source like a battery charger you should be able to direct test the motor. It should run for you on that voltage--watch polarity. Usually the problem is the mother board (main board) but fan motors go bad also. Main board number is WR55X10942 at about $!50 retail.
May 07, 2015 | GE Profile PDS22SBSRSS
I NEED OUTLET CONNECTOR CIRCUIT DETAILS OF 3615KL-040B96 REGARDS A.SHAALAN
not sure is that a small fan?? , just hook it up to 5 volts dc quickly to test direction even a 1.5 battery may run it and tell you which is + and -
if is a brush motor dc current.
if is a stepper motor it has to be a pulsed voltage necessary.
Oct 30, 2013 | Dell 3615kl-04w-b96 - Fan Pe 6800...
Do you have to replace the board upon replacement of the compressor fan?
Yes it will be needed to prevent damage to either the new fan motor or the motherboard. These models are costly and better avoided if possible to replace the refrigerator with a model that does not have electronic control parts, Sea Breeze
Feb 27, 2013 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
I NEED A REPLACEMENT FAN MOTOR. ANY INFO ON SPECIFIC CONTACTS TO PURCHASE MOTOR/
In the model number... I'm not sure of the fx and ms, but the 80 and 25 is a standard 80mm case fan that is 25mm thick. I tried a standard .2amp case fan that I had on hand and the circuit board did not like that..it got hot. I got on ebay and looked at dozens of 12v 80mm fans until I found one that was 0.09amps. That was as close as I was able to find without much more looking. The fan works very well although not quite as much airflow as the new crane humidifier that I put next to it but it doesn't overheat and does the job for about 7 bucks.
Mar 06, 2012 | Crane Frog EE-3191 1 Gallon Humidifier
The fans are not working. Would like to have part number to the fans.
The fan replacement is not hard, but it is fiddly.
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the cover and tapping the top of the cover to release the top tabs. Undo the screws on the metal plate which hold the battery in place. Take off the UPS outer metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the location of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan manufacturer's label should face the back of the UPS.
This solution is for a PW9120-1500. I assume your UPS is PW9120-3000 or larger. Check the model of the existing fans.
Feb 24, 2011 | Powerware 9120 UPS System
Need to replace the fan on a powerware 9120T 1500VA
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the and tapping the top of the cover to release the top tabs. Take off the metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the locaton of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan maufacturer's label should face the back of the UPS.
Jan 20, 2011 | Powerware 9120 UPS System
I need to replace a fan in my Client Pro 414, part number BP801512HL DC Brushless Fan Motor from Bi-sonic.
Any 12V 80mm x 80mm x 15mm computer fan with the appropriate connector will probably do. Power rating should be around 0.4A (yours should be 0.35).
Acoustifan's 80mm are the quietest fans, but I'd suggest Enermax Marathon (almost noiseless, great air flow). If they don't come in 15mm thickness, then SilenX Fan IXtrema Pro.
Nov 02, 2009 | MPC Computers ClientPro 414 All-In-One PC...
Interl fan inside the dvd recorder is not working
Check if there a voltage reading at the two lead wires of the fan.
Use a multi-tester, set 25 v DC. Put one prong at the motor terminal and the other prong to the other terminal. The reading should be 9 to12volts to make the motor run.
You can do these checking while your DVD cover is taken off, and with power on, for a short period only.
If the voltage is OK, then, your fan motor needs replacement.
Oct 14, 2009 | Panasonic DMR-E55 DVD Recorder
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Bad blower (fan) in Astec RS-PSU-450-AC1N
If you cannot find a exact replacement, don't worry, use a fixed speed fan, you only want to keep things cool, you care what speed it runs at as long as it does its job, and it is easier than replacing the bearings
Nov 28, 2008 | Computers & Internet
InFocus ScreenPlay 4805 Multimedia Projector Logo
463 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
