Question about Whirlpool Refrigerators
Our brand new whirlpool side by side refrigerator is not staying cool on the refrigerator side. On the recommended setting of 4, the temperature inside is 58 degrees. This happened to one we got two weeks ago and the store replaced that refrigerator and the same thing is happening again. Help. Susan Rogers
  • 828 Answers
You may want to look at your owner operator manual for the Whirlpool hot line for customer service. They would be able to walk you through a system check and recommend a solution to your problem.
Posted on Jun 29, 2008
The temp reads 65f. when I change it to 0-33 it goes back to 65f
Thank you for your post, janet!
I understand that your Frigidaire refrigerator is not displaying the correct temperature. Is it cooling? If it is cooling it could be an issue with your control panel or thermostat not registering the appropriate temperature within your refrigerator. I would suggest performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience a display problem or that refrigerator is not cooling I would recommend reaching out to a professional for proper diagnosis and repair. This will help you to avoid purchasing unnecessary parts. I hope this is helpful. -Matt
Nov 06, 2014 | Frigidaire FRS23KF7AB Side by Side...
I have a whirlpool refrigerator model wsf26d4exb00. the refrigerator side is cold only on the bottom but the top selves are warm
Make sure you condensor fan is running. Our gets clogged up with dog hair sometimes and when the fan cannot run the fridge cannot cool.
Aug 19, 2014 | Whirlpool Refrigerators
Whirlpool side by side does not stay cool or frozen.
You need to check the overload relay on the compressor and make sure that the coils near the compressor are clean of debris and duct.
Mar 30, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not cooling i bought it 2year ago new help
This could be caused by a few things. I would recommend that you make sure that the condensor on the back of the unit is free of dust, make sure that your temperature control is set properly. If those things are in order, then you may be looking at either the temperature control being faulty.
Mar 25, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have Whirlpool Gold Refrigerator side by side, Model# GC5SHEXNS05 Both side of the refrigerator stop make cooling, whenever I adjust the temperature back to recommended setting or whichever I prefer, it...
replace the control board part# 4334000 appliance parts pros the board goes bad if light bulbs blow out and theres a surge, but freezer still freezes
Oct 29, 2009 | Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Whirlpool gold refrigerator
YOUR FRIDGE DAMPER CONTROL COULD BE FAULTY IS TO THE TOP LEFT BACK OF THE FRIDGE COMPARTMENT.GOOD LUCK.MOHAMED
Sep 08, 2008 | Whirlpool ED2FHEXN Side by Side...
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Side by Side won't keep cool automatically
You need a new thermostat if it cycles off and not back on and as soon as you touch it - it comes on. Pretty common. Please rate my help as solved if i answered your question accurately.. Thanx!
Oct 03, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
