Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
None of the controllers match the one in the oven I have
Regarding KEHC309JSS. None of the boards are numbered or look the same. On the side of the board with the plugs, is stencilled 60D04010111.
After looking at the board again, I realized they have keyed the plugs so they won't go in the wrong way. They also stencilled the board to show the plug orientation. So that seems unlikely at this point. Do you know if there are different versions of this board for different ranges of serial numbers? Perhaps they changed the function of the door sensor???
Does it matter if the door is opened or closed when the oven is powered up?
thanks
-jeff
  • jeff845 Jul 07, 2008
    None of those links were very useful. The oven isn't throwing any error codes. The lower door switch just isn't working properly.
It appears they switched from a NO switch to an NC switch for the door sensor. I finally disassembled enough of the oven to get to the switch and it is NO, the part on appliance pros is NC. SO it must have been changed at some point. They should flag this on the board. You must replace the switch when the board is changed or the lower oven is unusable.
Posted on Jul 12, 2008
  • 2,071 Answers
Hi jeff I found a site more information about oven,more about error codes of the sensor.
http://www.repairclinic.com/0078.asp#KitchenAid
http://fixitnow.com/oven-repair-faq
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
http://www.repairclinic.com/0003.asp
http://www.repairclinic.com/0047_13.asp
jeff checked these site and message whatever the result...
Posted on Jul 02, 2008
Replaced bake element in Kenmore oven model number **********0
Hello;
My name is Peter. I am a retired field service appliance technician.
You did not provide a oven model number which should be on a label on the face of the oven when you open the door or on the side of the door. Locate the model number for later.
You need to go to a Lowe's or home depot store and spend $25.00 on a multi-meter. Read the manual and you will be able to know for fact what parts are good or bad. This is a good tool that you need for all of your appliances. I guess you spent about $70.00 or more for the element.
You replace a element when you notice a crack or a meter Ohm reading of OL.
There are three components beside the main control board (Which this is rare) that are the cause of failure.
1.) The element - which you have already replaced.
2.) The oven thermocouple - Which regulates the oven temperature. You can purchase this over the internet for about $25.00. Used parts are good. You need a multi-meter to check if the thermocouple is good or bad.
3.) The oven control board - If the two above components are good, then this is your problem. The oven control board is separate from your main control board. Depending on your model, your can purchase this control board from Sears for $200.00 - $270.00. Or you can go into the following website, put in your model number where you will get diagrams and part numbers, search the internet with the part number for best price.
Water Filters Lawn Garden Appliance Parts
Mar 30, 2016 | Kenmore Ovens
My clock display is also not working and the oven will on stay lit if I hold the oven knob manually ??
Have your make and model number ready and go to repair clinic dot com and it may show ya. Good Luck
Jun 11, 2015 | Ovens
Find that the oven is so much hotter than the temp. says
The oven temperature can be adjusted so that the dial and true temp are the closely the same. But I need the make, model number and serial number of your stove / oven to tell you how. The number are usually on the door side. J
Jun 06, 2015 | Ovens
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
My conveyor is not moving on my pizza oven any suggestions?? its a middleby marshall q360
These little motors are controlled by a rheostat for speed control, or electronic speed control. Follow wire from motor to control and check. Also; is chain on?
Jul 06, 2009 | Ovens
Jjw9630aab panel is dim
See other posts regarding replacement of capaciter #C3 on control board, cost of capaciter approx 65 cents.
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient
work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Mar 25, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Go to PF when there is none
wshort, As long as you are sure the circuit to the oven is not the problem,such as drop in voltage, here are a couple of suggestions. Number one is that the electronic parts for this model have a five year warranty on them and you may want to call for factory service. Sometimes the connections on the main control board become loose or corroded. Try reseating them and see if the problem stops. If not I would suspect the control board power transformer behind the control board. There are two transformers, one for lights the other for the control board. The control board transformer should have the red and blue wires while the light transformer will have the black and white. The voltage could be dropping out here. Make sure that the wires to the oven terminal block are not loose or burnt. Since you are not receiving any error codes except for PF, Im not suspecting the board itself. Catriver...post back.
Dec 26, 2006 | KitchenAid KEBC278 Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
217 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
