Computers & Internet Logo
I HAVE A DWA-300 THAT SHOWS LOW OR NO ACTIVITY WHEN I USE IT. SOMETIMES THERE IS A 9% SIGNAL, OTHER TIMES ITS AS HIGH AS 56%
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
What is code 13 and 56 on a 1994 Chevy Surburban
According to KnowStuff in myCarworks.com:
"Code 13: oxygen sensor is low, or in the case of two sensors, circuit is open.
Code 56: Code 56 : Transaxle speed sensor input circuit fault ( Cadillac )
- Vacuum sensor circuit
- Quad driver no. 2 circuit ( 3.8 L )
- Secondary air inlet valve actuator vacuum sensor circuit signal high ( 5.7 L vin J )
- Anti-theft system ( Cadillac )"
Where is the bank 1 sensor 1 air flow sensor located on a 2000 toyota avalon?
Sensor diagram for a 2000 toyota avalon and list of Pcodes dbd372cc-f8f3-49ef-b0c2-2adab46c4182.jpg 8fc069a5-bedc-447d-a1ef-4335798a0a0f.jpg
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 - Misfire Detected
P0302 Cylinder #2 - Misfire Detected
P0303 Cylinder #3 - Misfire Detected
P0304 Cylinder #4 - Misfire Detected
P0305 Cylinder #5 - Misfire Detected
P0306 Cylinder #6 - Misfire Detected
P0307 Cylinder #7 - Misfire Detected
P0308 Cylinder #8 - Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 - Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 - Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 - Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 - Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 - Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 - Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 - Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 - Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 - Circuit High Input (Bank #2)
P0334 Knock Sensor #2 - Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0441 and/or P0446
Turns on but no display
Many times it is the physical memory in your computer. You should get 3 beeps but this is not always the case. Sometimes you will get a 'No Signal' on your monitor. If your computer is turning on and you can see the HD light has activity I would check the memory.
Unplug the computer. Then open your computer (or laptop) and reseat the memory in the slot by popping it out. Do this a couple times and see if that does the trick.
D-LINK DWA 131 NOT INSTALLING DRIVER
Downlaod the latest drive from there website. The discs sometimes come with back drivers on them. http://support.dlink.com/ProductInfo.aspx?m=DWA-131
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
1helpful
I have an 04 Kia spectra with a PO121 code. What domestic this mean
Well.... Here is a full list of the codes I can find that Kia list. Oddly it jumps from P0120 to P0122
I hope the attached will help, but you may need to talk to your dealer.
Diagnostic Codes
Kia
Without Onboard Diagnostics (OBD-II)
2 Distributor no Signal.
3 Distributor G Signal.
7 Fault on SGT Signal.
8 Mass Air Flow Sensor.
9 Engine Coolant Temperature Sensor.
10 Intake Air Temperature Sensor.
12 Throttle Position Sensor.
14 Atmospheric Pressure Sensor.
15 Oxygen Sensor.
16 EGR Valve Position Sensor.
17 Feedback System.
18 Injector No. 1 open or short.
19 Injector No. 2 open or short.
20 Injector No. 3 open or short.
21 Injector No. 4 open or short.
24 Fuel Pump Relay open or short.
25 Pressure Regulator Control Solenoid Valve.
26 Purge Control Solenoid Valve.
28 Solenoid Valve (EGR) open or short.
34 Idle Speed Control Solenoid Valve.
35 Deteriorated Injector.
36 Deteriorated Air Flow Sensor.
37 Intake System Air Leakage.
41 Variable Inertia Charging System Solenoid Valve.
46 A/C Cut Relay open or short.
48 Power Stage Group 1 Malfunction (inside ECM). Injector 1-4 Purge Solenoid Valve, EGR Solenoid Valve or Damaged Power Stage.
49 Power Stage Group 2 Malfunction (inside ECM). Idle Speed Control Valve Failure or Damaged Power Stage.
56 Idle Speed Control Valve Closing Coil open or short.
57 A/C Compressor Input Signal short.
73 Vehicle Speed Sensor open or short.
87 Malfunction Indicator Lamp short Circuit.
88 ECM Data.
99 Battery.
OBD-II
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiency below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performance.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
Only high definitioncable shows picture other channels have interferance
Are you using a cable box and only some channels have interference? If so then have the cable company look at signal levels.
I have a ACER TRAVEL-MATE 800LCI...with wi-fi wireless...sometimes the wireless works some times it doesnt...what kind of router or what ever will help me get a stronger signal from my house...please help...
put up the high level things then you get it very stronger signal now you not get be'coz of the signal low strenght is not there so he can't caught the signal so pls change it in the high level
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
