Question about Brinkmann Smoke' n Grill Electric Double 810-5290-C
Brinkman electric smoker
Bought a nearly new smoker -shoulde it have a grate for wood chips in the center of the smoker - has a grate on bottom for water pan & one on top for cooking-- nothing in the center
    Problem Solver:
  • 11 Answers
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Posted on Nov 28, 2008
Model 20070410 masterbuilt smoker has the chip tray touching the element. will this burn out the element
Have the same "smokehouse" and faced the same issue today. First, ensure the Wood Chip Grate is rotated so the highest part of the Grate is to the left. Next , place the Water Bowl on the left (that highest part) and the Wood Chip Bowl w/ Lid to the right (balanced on the Grate so it doesn't fall through the supports.
Dec 01, 2012 | Masterbuilt 20070106 Electric Smoker
Can I use the wood chip pan directly (not the side chute)?
It is a big process it has 7 steps they are as follows
  • 1
    Soak hardwood chips in water for at least 30 minutes and up to 2 hours for larger chunks. Drain them completely before adding to the smoker unit. Use 1 1/2 cups of wood chips when smoking for less than 3 hours. For longer cooking times use 3 cups of wood.
  • 2
    Place the bottom unit that contains the heating element on a sturdy surface, away from flammable materials. Make a foil pouch containing the wood chips and punch a few holes in the top. Place this pouch onto the pan containing the heating element. The chips can be added directly to the pan, but the foil pouch makes cleanup easier.
  • Place the large water pan onto the unit and fill it 2/3 full of water or apple juice. The water or juice will moderate the temperature and provide moisture for the cooking food.
  • 4
    Add the cooking grates to the top of the unit and close the lid to allow the unit to preheat.
  • 5
    Place the food on the preheated grates and cook until done. Keep the lid closed as much as possible to maintain the heat. Open the vent on the top of the lid to allow the smoke to escape.
  • 6
    Check the water level occasionally by opening the door on the side of the Charbroil Electric Smoker unit. Add more water as needed.
  • 7
    Add more soaked wood chips after a few hours if the smoke begins to die away. This is optional; the chips provide flavor but are not necessary for cooking the meat.
  • Performance Chip
    May 22, 2012 | Old Smokey Electric Smoker
    How to use a char-broil smoker (charcoal) with wood chips smoking briskit. ( what temature should the grill be at ?)
    Hi hcf6886...
    To use your Brinkman Smoker or Other Smokers
    1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
    2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
    You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
    3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
    Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
    I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
    4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
    5...Continue adding wood chips to the tray as needed during the time you are cooking.
    If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
    6...Apply your sauce to the meat one hour before the meat should be done.
    Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
    Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
    Close the lid if it needs to continue cooking till you reach the right internal tempreture
    7...Test your meat with a meat thermometer after a few hours of cooking time.
    Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
    Close the lid and maintain your heat if it needs to continue cooking.
    Please take time to rate me.
    Sep 18, 2011 | Grilling
    There are not directions on how to use the smoker. Do you have have any instructions on using the masterbuilt smoker model 20020611
    Hi dan480volts...
    Maybe this will help you
    Sep 16, 2011 | Masterbuilt 20050106 Propane Smoker
    When using chips for smokers do you dump them as soon as they start burning
    Let the grill heat up first and stop flaming if using wood..
    After the grill is heated up to temp your going to smoke at then you add the wood.
    I will include some info for you also to help.
    2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
    You will soak the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
    Sep 06, 2011 | Masterbuilt 20070106 Electric Smoker
    How long and at what temp do i smoke rims with the masterbuild smoker
    Hi todd649...
    3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
    Once they are coated with gray ash, you can place the meat on the racks.
    I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
    Sep 05, 2011 | Masterbuilt 20070106 Electric Smoker
    I have never had a smoker before is the water pan the bottom one or is that the wood chip pan?
    Hi
    3...Start a fire in the smoker having the fire below the meat, but wait to put the meat on till the flames (if any) subside.
    Use the water pan below the meat (if you use one) to catch the juices from the meat...it will be above the pan with the charcoal in it.
    Use hardwood or charcoal for your fire/smoke,
    Once the charcoal/wood are coated with gray ash, you can place the meat on the racks.
    I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat, if you do not use a water pan.
    Monitor the tempreture
    Sep 04, 2011 | Grilling
    I do not have manual for using brinkman gourmet charcoal smoker
    Hi tsanelli...
    I could not find your user manual on the net, but I have this..
    1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
    Aug 27, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
    Have a brinkman all in one smoker but no instructions on how to use it
    Put the briquettes in the bottom pan and put the wood chips around the outside edge. Put water in the top pan. All this must be done before you light the charcoal. Using an electric lighter works best and won't change the flavor of your food like starter fluid will. After coals are lit, place meat on rack and seal everything up. Now you're Smokin'!
    Apr 06, 2008 | Rocky Mountain Range Outfitter 12" - OFTR...
    Frustrated-please help !!!!!!!!!!!!!!
    The problem is that you are not getting enough air into the smoker. What you need to do is drill some holes along the bottom of the smoker to let more air in. This is a notorious problem with that smoker
    Jun 07, 2007 | Char-Broil Charcoal Water Smoker 4654301
    Brinkmann Smoke' n Grill Electric Double 810-5290-C Logo
    287 people viewed this question
    Top Brinkmann Grilling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Gary Kenady
    Gary Kenady
    Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
