Question about Sony Playstation 3 (PS3) Console
Help? my ps3 got wet now it says it overheats like in 5 min ?
    Champion:
  • 207 Answers
Sounds like a blown fan.. new one is 15$ on ebay and about 15 min fix.. or ask sony.. or get an external cooler for 30$ at walmart...!!
Posted on Jun 30, 2008
My truck continues t overheat AI had the radiator changed out, the thermostat the fan clutch and another thermostat. had pressure and blockage test ran on it it passed but the truck sill overheats. I was...
The bleeding nipple would be near the water pump rad hose inlet and beneath the thermostat valve cover.
Bleeding is easy, just fill up the radiator and the reservoir w/ coolant run the engine for 5 min and open the bleeding nipples! or Just fill up the radiator before u start the engine, early morning, run the engine for 5 min. untill the thermostat valve opens, open the radiator cap( use a wet rag ), carefull not to open it instantly! Fill up the radiator while the engine runs, add coolant while u slightly reving up the engine.
Do these and open the heater to maximum, air might be inside the core too!
Hope that helps u out!
Jun 09, 2011 | Nissan Frontier Cars & Trucks
Ps3 doesnt display on my tv on regular plug and shuts off after 2 mins
The PS3 combines the features of a game console and a Blu-ray player in one device but like many highly sophisticated devices it can easily overheat. An overheating PS3 displays an LED on the front called the "yellow light of death" and shuts itself off after a few minutes. Repairing a PS3 system so that it doesn't overheat can be done at home, although you will need to open up the case and add heat dissipation paste to the GPU and CPU chips inside of the case. But it costs you more rather you can send the unit to SONY.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
When i turn it on it comes on and it could be 5
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Jan 21, 2010 | Sony Playstation 3 (PS3) Console
Loud noise coming from ps3 after short while
sounds like youmay have something stuck in the fan or in another moving part you may want to take it apart and clean it.
Nov 29, 2009 | Audio Players & Recorders
My playstion 3 will overheat and shut off after jus a few mins of playing ps3 games
it may be that you have used it too much or left it on for too long. send it too sony to get it fixed or buy a ps3 cooling fan to help
Sep 13, 2008 | Video Game Consoles & Games
Ps3 fan doesnt work?
I have solution for all of you. You need to call sony at 1-800-345-7669. They will send you a box so you can place you unit in (ps3). If you got warrany on your ps3 they will ask you to send in a copy to varify that it is still in warrany. If it is then they will not charge you anything they will open up the system and see what the problem is either fix the ps3 or they will replace it with a refuribished one. Also you need to make sure that the warrany tag on the ps3 upper right side is still there or they will charge you 150 dollars. And if the serial on the back is removed they will not even service your unit. If you unit is not in warrany they will charge you 150 dollars. Wich is real good because they will dust the interior of it good luck everyone...
Jun 29, 2008 | Sony Playstation 3 (PS3) Console
Help?
sounds like your cooling fan is not working... replace fan inside or place a fan blowing on back of unit for temporary use only
Jun 29, 2008 | Microsoft Xbox 360 Console
Overheating
Try to flip yur Ps3 standing and try to vaccum the dust out of the holes and try to prevent that dust to get inside the console.
click the Thank me Button XD
I helped all i can
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Shutting down on 60mg system
try holding the power button on the right
side of the console as you turn the back power switch on.Keep on holding the power button and see if there is a double beep.If this doesn't work,and if you want to try this? Open the HDD cover on the left side of the unit(front facing you).after removing the cover,remove the HDD unit and reconnect.It might be a loose HDD connection.This should only take you 2 mins to do and it won't void your warranty
Feb 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
