Question about Radio Shack Cinego D-1000 Multimedia Projector
Ballast How do you identify the ballast and how do you fix it? Is it fixable?
    Problem Solver:
  • 17 Answers
Fixable by a professional, and expensive $600.00 +/-
Posted on Jul 17, 2008
Have a 2004 vw new beetle 1.8 liter engine with a 20-v turbo charger. driver's side headlight not burning the day we picked up this car from used dealer. returned to dealer following day. they sent it
there should be h 4 halogen bulbs in the car that do not require a ballast
ballasts are an after market fittment to run LED lights
if there is no requirement for the ballast then yes warranty is void
I suggest that you take it to an accredited auto electrician and discuss the problem as to why it would have a ballast and the potential wiring problems that could result
Mar 24, 2017 | 2004 Volkswagen Beetle
Ballast uart
The ballast powers the lamp. Keep the old lamp. I think it will work once the ballast circuitry is fixed
Dec 18, 2013 | Office Equipment & Supplies
How do I fix the ballast in a KDSR60XBR1
For the most part a ballast is not "fixable" it is sold as a part--complete.
Tell me what set is doing including what lights on front on or blinking?
If you blindly just want to replace it GOOGLE THE MODEL NUMBER WITH BALLAST to locate the part and price for it.
Mar 27, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing sound, resets 8 times, and then turns off. Bulb replaced
Actually ballasts run between 60-80 dlls. It does sound like you doi have a ballast issue, everytime a TV resets the ballast is the issue. Go to discountdashmerchantdotcom you'll see the ballast prices. Plus they also have free troublehsoot.
Aug 25, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52HM84 Ballast replacement help
It is very easy to fix/reolace the ballast in these sets. I just fixed the ballast in mine yesturday,by replacing a single resistor on the ballast board (the resistor is labled R3 on the ballast), Google "Toshiba ballast replacement" and there is a nice write up with pictures to guide you through it. If you can soulder you can fix it and save alot of money.
Oct 07, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Fixing a ballast
no our problem was not fixed.
Jul 12, 2008 | Televison & Video
Ballast location?
the ballast is right in the middle. you should see an electrical cord. open the 2 screws from the ballast cover. then unscrew the top and bottom screw from the ballast. the ballast should come off. cut the wires closer to the ballast, so that you can identify the wire with the new ballast, which will have the same color scheme.
Jun 17, 2008 | True GDM-41 Refrigerator
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
128 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
Frank Zabroski
Frank Zabroski
xxxxxx xxx
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
