I have a Bendix Autowasher 800 washig machine. The door lock seems to have broken, with a load inside the machine, and I can't open it to get the load out. The cycle has finished. I think I broke it by trying to open it after I had started the machine, and put to much pressure on the trigger inside the handle.Is there anyway to open the machine without doing further damage, and is this something I can fix myself? Thanks very much
Have the same problem myself.
Remove top panel from washing machine by undoing two fixing screws to rear and sliding panel forward to front of machine.
Door lock is located internally on right hand side, its difficult to reach and I had to loosen the control dial and switches to gain access.
However it may be possible to release the mechanism by touch.
At the back of the lock mechanism the latch protrudes by approx 3 mm if you can see it or feel it you only have to apply some pressure to the projecting end to release the latch.
The broken release lever can then be removed from the door and replaced by a new part which cost about €6.
Posted on Jul 14, 2009
Hoover softwave autowasher 1000 door mechanism broken
the door interlock has failed
youll need to check the machine is empty
remove the mains power supply
and then the top lid
and use a tools small screwdriver etc
to teeze the door open
from inside
then replace the door interlock by removing a couple of screws or releases and replace it by plugging a new one in
checking the door release also for damage
all the bits youll find easy on ebay
and should cost no more than £25
if you dont feel up too the repair at least you can get your clothes back
Oct 30, 2014 | Hoover Washing Machines
WFW9200SQ00 Whirlpool washing machine. Door strike doesn't go in the latch, seems a mechanical issue. There is a little white pin inside the latch on the way. Any ideas what can be wrong?
Does the door strike seem to be broken and is that what you see inside of the latch asm.? if no the strike is ok i suspect the latch itself has broken apart and your seeing a internal part of it through the opening where the strike fits into, in which case the latch/lock assambly would need to be replaced.
The part numbers are
DOOR LATCH ASM. 8183270
DOOR STRIKE W10217552
GENE
Oct 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
How do you open a locked door on my washig machine?
Unplug machine from wall. Remove bottom front panel. Reach up inside the right towards the latch assembly. There is a pull down tab at the bottom of the door latch. Pull down on tab, door lock should release. Be prepared to catch any water that may be inside the drum once door is open.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bendix 800 autowasher de luxe, drum spin snagged then cleared.
should b nothing off this description on ure machine unless the pump coil has over heated iff so just replace coil and check for blockages
Jul 13, 2009 | Tricity Bendix AW1000W Front Load Washer
Is my bendixx 1000 autowasher hot or cold fill
Look at the top left rear of the cabinet, there you will see the connections for the inlet valve(s), if there is only 1 then it is a cold fill only, if there are 2 connections , then it is hot and cold fill.
They are normally marked H and C.
Plz leave feedback for this solution.
thanks.
Dec 17, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Wahing machine Tricity Bedix AW1260W-Door problem
probably handle mechanism broken. to open is a bit difficult.
disconnect from mains and take top off.
feel down the cabinet front on the side where the door handle and opposite the door handle you will find the door interlock. in the door interlock, you will find the end of the door peg. force this towards the middle of the machine and with luck the door will open.
anothetr method is to break the handle off and use a small screwdriver on the door peg
Jul 21, 2008 | Tricity Bendix AW1200 Front Load Washer
put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Jan 03, 2008 | Tricity Bendix AW1000W Front Load Washer
Bendix washer-dryer door won't open
if you remove the panel in the front lower right hand coner of the washer you should be able to feel around in there for a plastic cord. pull the cord to manually unlock the door
Nov 24, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
