Question about Toshiba Satellite M35X-S111 Notebook
No power up on Satellite M35X-s111
So nothing shows on the screen. Fan blows 5 sec. and thats it. all power lights are on and nothing else.
Do you have any suggestions? could it be a dead battery?
  • Anonymous Aug 23, 2008
    my computer use to come on and stay on very brefly and then go out! it dosen't seem like a major problem, but you never not. my e-mail is "Charl4turn@peoplepc.com.
Heres the fix:
This requires access to the cpu and heatsink, remove the keyboard and palmrest to access the motherboard, I think you have to remove the screen too. Remove the heatsink and cpu. Reseat the cpu, heres the kicker, press firmly on the center of the cpu while turning the locking screw. Pressing the cpu hard, allows the locking mechinism to get a good bite. Turn the locking screw hard into the end of the turn. Hook up the heatsink and set it back on top of the cpu. Press down on the heatsink over the cpu, fairly strong pressure.
Now test the motherboard, use just cpu, heatsink, memory, power button board and cable and external monitor, you can use your screen instead by just hooking up the cable to motherboard, leave the screen laying flat on the table. Now push the power button with one hand and the other is still applying pressure to the heatsink, no you dont need to screw it down yet. Keep reseating the cpu with varying degrees of pressure if you dont get it go the first time.
The trick will be to get it all assembled with the same results.
There seems to be a problem with the cpu seating correctly, it must come loose and the laptops exhibit the symtoms of no video. It might even be neccessary to insert a wafer thin piece of copper or something in between the cpu and heatsink if the heatsink doesnt apply enough pressure to cpu to keep it seated deep enough to run the computer.
Posted on Jul 24, 2008
After fixing power jack problem secreen will not lit
toshiba satellite M35X-S111
After solving the jack problem.
when I click on the start button I hear the fan voise but there is nothing on the moniter and no sound.
When I remove the connection between the start button and the mother board and put it again it works two times and then the problem started again.
The computer may work random at sometimes.
Is the problem in the small board and the cable which between the start button and the mother board ?
If yes how to purchase it
Dec 12, 2009 | Toshiba Satellite M35X-S111 Notebook
Toshiba satellite m35x-s111 will not power up
there was a massive recall on these laptops years ago entailing that the mother board be replaced. unfortunately that is gone and passed. this is a problem with every m35x and most honest repair facilities shy away from those repairs due to the likelihood of the machine failing again.
Oct 22, 2009 | Toshiba Satellite M35X-S111 Notebook
Power on but no screen oor hard disk motion
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Sep 11, 2009 | Toshiba Satellite M35X-S111 Notebook
My M35X-S111 keeps shutting down
More than likely it is overheating you can buy a can of compressed air and blow it out if you dont have a compressor that should be done at least every 6 months
Aug 06, 2008 | Toshiba Satellite M35X-S111 Notebook
No power on
I believe that the syptoms you are experiencing include the power button lighting up during start up and the fan cycling for 5 seconds, but no other activity. There may or may not be a series of audible "beeps". A CD will come up to speed, but will not load. I have had this happen three times with my M35X-S111 due to it not being able to recognize the RAM. The first two times, I re-seated the RAM and it successfully booted. The third time, I reseated the RAM 50+ times with it only successfully booting once. The slot that holds the RAM cards does make a good electrical contact with the cards. Since the RAM holder is integral to a card, you cannot replace it with a "generic" holder, instead, you have to replace the entire card. I discarded my Toshiba after that third failure.
Jul 01, 2008 | Toshiba Satellite M35X-S111 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M35X-S161 will not start up...lights come on but no power up???
Hi, Toshiba extended the warranty of the M35 till Nov. of this year for this same problem. If you just contact Toshiba support, they'll rplace the board no charge. I've had a few repaired. They only take a few days. Good luck,
Sep 21, 2007 | Toshiba Satellite M35X-S111 Notebook
Computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
320 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
