Question about Frigidaire Refrigerators
Motor runs continuously. Frigidaire freezer model GLFU1767FW Temperature control has been replaced & works fine. Temp set at max ( 10F) All conditions seem OK except continous motor running
  • 1 more comment
  • mgsaluto Jun 29, 2008
    Yes, all is OK & frozen.
    Perhaps it is the thermostat; the freezer is only a few months old & nothing is dirty. Since I cannot check compressor or refrigerant leak, it seems I need a service call?
  • mgsaluto Jun 30, 2008
    Thank you very much for your patience & attention. My words have misled you. The thermostat is set to the max high temperature (+10F), not the max low temperature (-10F). Therefore I am not asking the thermostst to freeze to the coldest temperature possible. I am only asking it to stay at the "highest", "warmest", & "easiest" temperature setting. So, I still have a problem: it keeps running at the easiest freezing temperature setting. Do you have any further advice? Thank You.
Well in that case or the termostat is defective or is bulb is not well placed. try to see were is the end of the bulb fixed
Posted on Jun 30, 2008
If is continuos running and freezing you have a problem whit the termostat if not must see the condenser unit if is properly cleen or if there is a fan in the condenser unit if is running.after that could only be the compressor or a leak
Posted on Jun 29, 2008
    Problem Solver:
  • 5 Answers
Continuus runinng but freezin or not?
  • Karvalhal Jun 30, 2008
    You must set the termostat not at the maximum.if is set to the maximum it never stops like in any other freezer.
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Mar 26, 2016 | Kenmore Refrigerators
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
May 03, 2015 | Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Apr 25, 2015 | Refrigerators
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
Temperature control of refrigerator/freezer not working
Let me know if the compresor and the condensing fan motor works beacause most of the times the problen is not in the temp control.But if you whant tomake sure that the temp control works or not you can pull the two wires out from the temp control and put a jumper wire between them and if starts cooling you just need to replace it
Apr 21, 2009 | Refrigerators
Refrigerators Logo
183 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
