Question about Kenmore Dryers
Kenmore series 90 plus dryer
My dryer is taking a long time to dry the clothes. I think the heat element is going bad. How hard is it to change it and how do I go about doing it?
Thanks,
Uel
P.S. It is electric.
  • ukemp Jun 29, 2008
    My dryer is taking a long time to dry the clothes. I think the heat element is going bad. How hard is it to change it and how do I go about doing it? It is an electric model
    Thanks I'll check that.
  • 413 Answers
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers.
Check the exhaust hose in the rear of the machine and make sure it it not crushed, kinked or clogged with lint. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers or this website http://www.linteater.com/.
Posted on Jun 29, 2008
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Kenmore 90 plus series stopped drying my clothes
heating element is probaly bad it shoud have two of them easy to replace BUT UN PLUG FIRST elements probaly around $100 for both easy fix
Mar 01, 2012 | Kenmore Dryers
I have a series 90 heavy duty electric Kenmore dryer. I think the heating element has gone out. Is this an easy fix. Dryer still works just doesnt get hot to dry clothes.
If The front panel is one assembly then the element is on the back behind the cover, if there is a small panel on the bottom ending about where the door starts the element is behind that panel on the right hand side. In either case it if fairly easy to get to. Also check the two thermostats on the heating element. Both should have continuity. If either one is open replace them both.
Jan 31, 2011 | Kenmore 62802 Electric Dryer
Dryer is working but do not emit heat so clothes do not dry
The problem is that the heating element has failed. This is an easy repair and if you are handy you can get all the information you need from the sears web site to assist you in changing the heating element. Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at www.managemyhome.com
The repair part is also available from sears parts deptartment (www.searspartsdirect.com) and will be about $50 guessing.
Best wishes!
May 11, 2009 | Dryers
Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Jan 30, 2009 | Kenmore 62602 Electric Dryer
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Dryers Logo
148 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
