Question about Haier HTX18GAAWW Air-Cooling And Automatic Defrosting Refrigerator
Orange star button inside fridge
Can you tell em what the purpose of the oragne star button inside the fridge next to the temperatue control is?
Also how do I defrost ? I have a whirlpool fridge freezer with no instruction manual,
Many thanks
Mark
  • mark108 Jun 30, 2008
    Thanks for the reply; the problem was that the freezer section got toally iced up and in order to defrost it I switched off the whole machine. I notice that there is the ornage starred button next to the temperature control and was wondering what that was for. If pushed on is it to defrost do you know?
  • James Helmer
    James Helmer May 11, 2010
    Most refrigerator freezer made today are frost free and defrost is automatic unless there is a problem. If there is a fan in the freezer section it is a frost free model. Exactly what is the nature of the problem you are having?
  • 828 Answers
There is a defrost timer that starts the defrost. It may be in the section where the temperature controls are located. You will find a round hold with a clutch head screw accessible through the hole. Turn the screw clockwise SLOWLY until you hear one audible click. The system should then be in the defrost mode. Wait about 25 minutes and if the timer is good the system should go back into the cooling mode. If it does NOT, advance the timer to the next click and get a replacement timer. The defrost should have taken place if there is no other problem. If the unit went back into the cooling mode and defrost did not take place your problem is in the freezer section behind the rear wall. There you will find two items, a defrost heater and a defrost thermostat. You can check out the heaters with an Ohm meter. No reading, open, means replace the heater.
Posted on Jun 30, 2008
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
Inside my fridge there is a round manual termostat that is numbered 1...to 7 i like my fridge cold so what 1 would i have 2 have it on ..also up over the top of the door there is a button wit a pic of a...
firstly the button that turns orange is the freezer "fast freeze"control,you use this when you have defrosted it or move it to another house,the control in the fridge should be set so that the interior is at +2c to +5c,1 is the warmest 7 is the coldest,if you havnt got a fridge thermometer,do the lettuce test,if the leaves go black/soggy,its too cold.
Dec 22, 2010 | Whirlpool GB9SHKXL Bottom Freezer...
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Feb 06, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Frs23h5asb6 is freezing food on refrigerator side. Turned refigerator control off, still is 33.5 deg. Took out all bags to increase air flow. Is thermostat bad?
first of all are you talking about summer or winter, i dont know what state you live in. the weather and humidity play a big part on your unit,is your kitchen as warm as in is is winter,if not turn down the freezer control down ,turn on refrigator control 1/4 of the way.until you get both sides of the unit working at the right temperatue.you may have to adjust the settings a few times.using the freezer and refrigerator controls back and forth. also in the summer you can usually back down the controls to adjust in the temperatue change. no more frozen lettuce in your fridge,i hope.,,,,,,,,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
On button is orange and moniter wont come on
If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
If it still doesn't work you have a bad video card.
Hope this helps
TankMurdock
Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
Orange circle with a flashing exclamation point.
this usually indicates a gearbox fault. take it to a garage and they will plug a laptop into the vehicle and tell you what exactly the fault is.
hope this helps.
Mar 18, 2009 | 2000 Mercury Sable
Unlocking problem
again you call customer care centre and tell the problem it is repeating what i will do? they will help you!
Jun 30, 2008 | Sony Ericsson K550i Cellular Phone
Is my fridge energy star rated?
ALL ENERGY STAR APPLIANCES HAVE A "ENERGY-STAR LABEL" USUALLY LOCATED ON OR NEAR THE MODEL AND SER. NUMBER TAG OR LABEL. CHECK ON THE BACK OR INSIDE THE REFRIGERATOR WHERE THE COLD CONTROLS ARE LOCATED.
Apr 26, 2007 | Kenmore 53612 / 53614 Side by Side...
Haier HTX18GAAWW Air-Cooling And Automatic Defrosting Refrigerator Logo
310 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
