Question about Canon Cameras
CANON A720IS How do I access DIGITAL zoom on the menu. Dimmly shows as a menu option but paging down skips the selection. Currently shows [OFF] ALSO My manual recommends formatting a new SD card. Is that necessary?
Let me get this straight---You want to charge ME $9.95 to answer my question---but you want ME to post the solution FREE?????
Posted on Jun 30, 2008
I am unable to set the Digital Zoom to On, in my Canon G12. The Digital Zoom Option in the Camera Menu always seems to stay blanked out no matter what I do. Discussions with fellow G12 owners did not...
The digital zoom setting is only available when the aspect ratio is set to 4:3. The setting is accessible by pressing the 'func.set' button in shooting mode.
Mar 17, 2011 | Canon G12 Digital Camera
The menu in my canon sx10 is camera where the digital zoom is located is not "illuminated" as a menu selection I can pick to turn the digital zoom back on. If I try to pick it from the menu, it...
There are certain modes that you simply can't get digital zoom in (such as widescreen mode). If that isn't the problem, perhaps it's not enabled. According to the manual which I believe is here: http://gdlp01.c-wss.com/gds/7/0300001567/01/PSSX10IS_CUG_EN.pdf on page 54 of the manual (p56 of the PDF) it shows that the digital zoom can be enabled in the FUNC menu (in a record mode). The description of digital zoom, including the safety zone, which might explain why you can't get digital zoom under certain circumstances, is on page 68. Note that there's a big chart on page 286/287 that shows what features are available in each mode - I have a feeling that this could be your problem.
Feb 19, 2011 | Canon PowerShot SX10 IS Digital Camera
How do i set self timer on canon A720is
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
Aug 03, 2010 | Canon PowerShot A720 IS Digital Camera
I have a Canon IXUS 40 how do i turn on the digital zoom
Heres the support site for that model http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=10599
I would never use the digital zoom on a camera, as you can do exacttly the same on a computer - so keep the full optical setting and the you can zoom in and crop using a PC - with a lot more control
Apr 07, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
How do I use the self timer on my Camedia c-4000?
Turn it on.
Press menu button (bottom right beside monitor)
on the Drive menu, press right arrow (on the navigational arrows - top right) to move to selections.
Move down four options - the one with "the little clock (pointing to 11pm) and a radio".
Press o.k. (the button with the green key underneath)
That should now show the clock as the selected option on the drive option.
Press menu one final time to exit.
Camera is now in timer mode until you reset back.
To reset back > press menu - at drive menu - select the top option (looks like a single page image) - press o.k. - press menu
Feb 07, 2010 | Olympus Camedia C-4000 Zoom Digital Camera
Internal dust speck on Canon A720is in same upper right corner
If dust is in the camera, it must be opened. I suggest not doing this yourself. Lookup a Canon dealer in your region and ask for support.
Jul 22, 2009 | Canon PowerShot A720 IS Digital Camera
I'm not able to set the digital zoom
You can turn on/off the digital zoom. While on shooting mode, press MENU button and go to left end tab menu items. Navigate to "Digital Zoom" and select the desired¡red setting: ON or OFF. Remember that digital zoom can't be used if the screen is turned off.
Jul 15, 2009 | Canon PowerShot A620 Digital Camera
I have got a Canon Powershot SX100 IS, but when I connect it to the television to see the pictures they show on the TV in black & white. Can you help ?
  1. Press the Menu button,
  2. go to the Setup "Tools" menu,
  3. scroll down and select the "Video System" option.
  4. If you live in the US, set it to "NTSC" video format if it's in Pal. You may have to select Pal for television in some countries overseas. Either way, set it to the other option than you currently have selected.
That should do it.
Jul 11, 2009 | Canon Cameras
Digital zoom using powershot sx10is
On shooting mode, press MENU,then move down to Digital Zoom. Use right or left buttons to change the digital zoom options. For example: you can set on 1.6x, 2x, etc.
Jun 06, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Cameras Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
