Question about Frigidaire FAC124 wall/Window Air Conditioner
Unit stops working and I need to unplug unit
This remote control unit has been working fine for 7 years. This year I notice that it will be blowing fine and then suddenly the temp control changes to #5 or #7 and only the fan will be working. I need to pull the plug because the remote or manual does not work. Then when I plug the unit in again it starts to work. Should I call the electrician or call be service
  • facemelter Jul 10, 2008
    I have this exact same problem, except my unit is the FAS155M1A1. It's only four years old. Occasionally after pulling the plug to resart it, it simply will not come back on. Sometimes it works fine for a bit, then shows a partial display, and runs fan only, other times it loses the display completely. Once the display is partial or off, the on/off button (or any button) doesn't work - and you're forced to reset by pulling the plug.
    It seems to me very much an electronics/controller issue, since everything else works great when its functioning.
    Problem Solver:
  • 8 Answers
After 7 years of great service you should retire this system and replace it with a new unit.
Products made these days are not built for quality, that was back in the good old days, it's 2008, things are made to only last a short period of time.
Sorry I couldn't be more help, but I will only tell you the best solution for your problem and not waste your time running around trying to fix something that may cost you more than replacing the problem you already have.
Have a Great Day!!
Glenn
Posted on Jun 29, 2008
My remote is not being received by the unit. Unit works fine, and remote is emitting IR. Tried syncing remote but nothing, and cant use the unit without the remote.
8 YEARS has exceeded it's life expectancy by 3 years already as they consider 5 years as a life time in the electronics industry
Jul 02, 2015 | Toshiba RD-XS34 DVD Player/HDD Recorder
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
My remote only works on 1 and 2. # 3 does not work . How do I fix this?
You posted under Woods timers.
Woods makes a few different timers with remote.
One of them has 3 buttons
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
You can try unplugging all 3 remote units so they reset, and then try setting up on button #3 first.
You can also work around using this method: unplug all remote units. Plug in two remote units and turn both lamps ON. Then use button #1 to connect to both of those remote units simultaneously. This way, two different lamps can be controlled by one button.
If remote control is genuinely defective, then send it back for replacement.
Industry-standard is one-year limited warranty.
I own 2 sets of this timer.
One of the remote units stopped working immediately and has never worked since.
Both the remote controls work, but only 5 of the 6 remote units work.
I test timers and 6-8% arrive defective. Most go bad after a few years, some last quite a while.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 24, 2011 | Woods Hardware & Accessories
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Feb 24, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
Coil and fins start ice up
The fins are dirty. They need to be washed every year or two with an acid based cleaner. They MUST be rinsed completely.
Jul 21, 2009 | Carrier 38CKC030 Air Conditioner
Hi have central air . Unit working ok but noticed not blowing cold air . The fan outside is working , Unit comes on . Could it be feron . unit it about 7 years old . Purchase house about 4 years ago
You need to have a pressure gauge the reads for R-22. (Freon) It sounds like the system might have a leak. Look for a wet place any place on the units pipe system. It has a little oil in with the freon that is forced out of any leak. If you see a wet place this is oil. It is also the location of your leak.
Jun 27, 2009 | Heating & Cooling
EVerstar Portable A/C
I have the same problem how can i solve this problem>
Sep 03, 2007 | Danby DPAC8020 Air Conditioner
Frigidaire FAC124 wall/Window Air Conditioner Logo
207 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
