Adjusting curtis mathes projection tv model fp4600ek02
Our tv has 3 color shadows in the picture. can it be adjusted or is it broken?
  • 552 Answers
If this tv is more than 10 years old, I would say the three projection tubes are getting weak.
This may be a good time to invest in a new tv.
considering the difficulty of obtaining parts for it and the other problems you could have in the near future, it would be cheaper to replace the tv.
If the tv is not that old, please let me know the model number for more assistance.
Posted on Jul 02, 2008
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
Red & green shadowing on the right side of picture
tried to adjust the convergence settings in the menu in the color adjustment in the tv menu. if can not adjust, you have bad either an open resistor or bad ic in the convergence circuit which control the color adjustment.
Aug 08, 2013 | Hitachi 60EX01B 60" Rear Projection...
Shadowing of picture
A shadowy or 3D image is caused by the convergence not being aligned. If your model has a convergence menu goto it and see if you can adjust the colors so that they are all straight and aligned. If so the 3d shadows will go away. If however it wont adjust the convergence has failed and would need to be to repair the TV yourself or with a company. Convergence repairs are common a fairly easy DIY fix.
Apr 20, 2013 | Mitsubishi WS-55819 55" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My picture in my television is like shadow box size but not a normal shadow box program. When the t.v. is bumped the picture goes to normal then back to small , What is obviously loose?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 24, 2010 | Hitachi 43FDX01B TV
Seeing double with the picture - a lot of shadows with the picture?
•Screen looks 3D
fcabb43.pngCONVERGENCE SOLUTION
Aug 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Colors not matched
Yes,there are convergence alignment adjustments, to be adjusted
by a technician after set is repaired.Replace STK392-560 IC's,then
check alignment..........T.
Oct 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
