Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Reply thanks Mike I will try turning it down a little less cold. Does a frig freezer like this get more broken in as time goes on with the door seals on the freezer or will it always get little vacuum to it? thanks
  • 481 Answers
  • it will probably always do it a little.
  • but for me it is a sign of a good refrigerator.
Posted on Jun 29, 2008
Freezer working fine, but frig not very cold. I did notice a little ice inside freezer on top side
TOTALLY defrost your freezer. Make sure there is no ice left in the bottom, in the passages into the fridge.
Check your door seals. Put a dollar bill between the unit and the door. You should feel resistance when you pull it out. If not, replace the seal. The door MUST be absolutely flat when you replace the seals.
Dec 13, 2012 | Refrigerators
I opened up my frig and the temp said the freezer was -13 and the frig is at 55 degrees. When I presed it down it changed to 2 in the freezer and 32 in the frig part. Put after about 3 to 4 seconds it...
the damper vent door between the freezer and fridge compartments is frozen shut or if motor operated it broken or the motor is bad or power to motor is missing to open and close this door to let cold air into fridge from freezer also there is an evaporator fan near here make sure it is operating or cold air wont be moved
May 22, 2011 | Refrigerators
Frig is 11 months old. ice is forming on vegetables in the bottom right crisper despite turning refrigerator down to 2 from 5 factory setting. this did not happen for the first 8 months. any suggestions?
Try turning freezer control to 7 and check 24 hrs.
Why ??? the freezer control is usualy the damer door control between the freezer and freshfood side... by turning the freezer up you will be closing the door to the freshfood side giving it less freezing cold air. :)
If this does not solve your problem the you will have a Thermostat control problem.
Oct 06, 2010 | GE Refrigerators
My older KA Ref Model KTRP20K & M is giving off a strong odor similar to iodine. Very strong in AM but can still smell it in PM. I've checked for spoilage and nothing there. Any thoughts? Is it time...
since it is working ok . i am wondering if you dont have mold growing in the drip pan ... condensation from inside the refrigerator goes down a small tube in the back bottom of the frig ... that tube goes to a pan under the refrigerator and normally the water just evaporates .. if there is a lot of condensate from the frig then the pan may stay wet long enough for mold to get established ... a large amount of condensate from the frig usually indicates a leaky seal around the door .. or a door that doesnt close completely .. you might want to clean everything under the frig including any fans, coils and that pan (unplug first) ... now this all assumes that the smell is coming from the outside not inside the refrigerator .. if the smell is inside then you may have to defrost and clean the evaporator (the coils inside the freezer (somtimes also in the refrigerator) ... there are some kinds of mold that actually grow in that cold environment .. some hot soapy water with a little bleach usually does the job .. or if you have one, a steam cleaner, those do great .. it allows you to get down in the little places and clean everything ... make sure the frig is at room temp first so plastic doesnt crack ..
the refrigerant r22 or r134a have very little smell so even if you had a leak it wouldnt smell strong .. a few refrigerators use ammonia and that would have a distinctive smell easily recognized if there was a leak .
Nov 22, 2009 | Cell Phones
Frosting up of freezer fan/fan runs continuously
Clean and check the seals around the doors, the unit is trying to compensate for temperature loss.
Jul 27, 2009 | Refrigerators
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore doors getting air vaccum and will not open right away
  • that is just a sign of a very cold freezer and a good sealed refrigerator.
  • if you don't like it then turn your freezer down so it wont get so cold.
Jun 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
