Question about Kenmore 24032\24036 Top Load Washer
My kenmore washer is overfilling even though I changed the pressure switch
I changed the pressure switch on the washer but the machine still overfilles. The clear plastic tube is connected to the pressure switch but perhap the connection in the tub is loose.Where does the tube connect to in the tub or am I ging about this all the wrong way
  • Anonymous Mar 17, 2014
    How to open main panel to diameter rubber hose that connects to the pump to the bottom of the outer tub
  • 5,911 Answers
The clear plastic tube runs from the pressure switch to the air dome on the lower right-hand side of the wash tub. If the air dome end of the hose were loose, water would begin to spill out of the bottom of the washer when the level in the tub reaches only a few inches.
If the washer is filling the tub completely, but your pressure switch is not shutting the water off, you will need to confirm you have a good electrical connection, and that you do not have a small hole in the air hose somewhere. It is possible for the air hose to develop leaks where it contacts the washer casing and begins to chafe. If your electrical connections to the pressure switch are secure, trace the wires back to the timer and make sure you have good continuity. There should be a wiring diagram located under the operator console. Please refer to the following link for instructions on how to access the inside of your washing machine:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
I know the instructions are for replacing a motor coupling, but the steps are still the same for opening the console and removing the outside washer casing. Please let me know, if you require further assistance. If you don't get anywhere with this advice, please post back with your complete model number. It may help me further with diagnosing your problem. I hope this provides you with a solution.
PS I apologize for taking so long getting back to you.
Posted on Jun 30, 2008
Kenmore Elite Oasis topload washer overfills. I have replace the pressure switch hose but it did not solve the problem.
If you have gotten that far, you've done good.! I'd say to look at the painted screw on the pressure switch.. Needs to be turned. In clockwise direction to make sure diapham closes.. Or it's possible the circuit board is gone out..
Dec 02, 2016 | Kenmore Washing Machines
The washer overfills
if you unplug it and the water keeps running replace the valve where the hoses are connected to but if it overfills and the water stops when you pull the plug replace the pressure switch
Jan 16, 2013 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 70 series washer over fills
there is a plastic tube that runs
from the tub to the overflow switch in washer. If this develops a hole in it, air
pressure is not applied to the switch to shut it off. good-day !
Dec 17, 2011 | Kenmore Washing Machines
I have a Kenmore model 70 washer, I changed the mixing valve, and now the washer is overfilling, and will continue to flow water. causing the washer to overflow,
Check the small air hose on the pressure switch inside the operator console. The following link explains:
http://www.fixya.com/support/r3575901-washer_overflows
The hose can sometimes come loose when doing maintenance, or from years of vibration. If the air hose is intact, check for any splits, cracks or holes in the air hose. If the air hose is not air tight, the pressure switch will never detect the water pressure differential from the wash tub as it fills. If it never detects the pressure, it will not shut off the water inlet valves.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate under the wash tub rim under the lid) and let me know. I hope you find this information helpful.
Dec 16, 2010 | Kenmore 22422 Top Load Washer
Our kenmore washer overfills with water
Sounds like the pressure switch that senses the water level is bad. Here is a link to the part.
http://www.appliancepartspros.com/Appliance-Parts/?keyword=pressure+switch
Nov 21, 2010 | Washing Machines
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I test the pressure switch on kenmore washer... My washer keeps overfilling.
Loosen hose at tube turn on washer blow in tube water hould sop and it should begin agitation.
Mar 12, 2009 | Washing Machines
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
582 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
