Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57H81 Blinking power light
The red power light on the front of my 57h81 Blicks but there seems to be no code. when you hit the power button it will display a steady light then begin to blink with no code. i can't find a fuse and it acts like it wants to turn on then the light starts flashing. red light blinks.no picture.no sound
  • 1,879 Answers
Greetings,
Power supply cannot sustain / provide juice to the whole system.
If you are qualified to do electronics, check the power supply section, otherwise contact a repairman.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 29, 2008
57H81 57 in. Rear Projection Television: My Toshiba model 57h81 is 5+ years old. It just s...
I had the same issue with my 57 in. Mitsubishi. I fixed it by buying a new projection bulb. The Mitsubishi manual indicated this was the fix for my Mitsubishi TV. Be advised that new projection bulbs are not inexpensive. My TV works like new once the projection bulb was replaced.
May 03, 2010 | Televison & Video
Red light on front power is blinking, pinkish color and long time to warm up before it went out.
your crt bulb is out and this repair is costly it would be cheaper to replace with a flat panel tv
Oct 19, 2009 | Toshiba 57H81 57" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
Jul 11, 2009 | Toshiba 57H81 57" Rear Projection...
F470 fuse location
REPLACES THE CONVERGENCES IC'S
Mar 19, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 red light blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 14, 2017 | Toshiba 57H81 57" Rear Projection...
I have a 57h81 no picture no sound red blinking light
dont have the board number but it's the one with the silver heatsinks
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 07, 2008 | Toshiba 57H81 57" Rear Projection...
Power light blinks at one second intervals
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 03, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
This sounds like the typical toshiba power regulator ic fault. it begins with an str##### Its not something a handyman should try to tackle. It should be repaired by a quilified repair person Sorry Good Luck
May 22, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
248 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
