Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Not cooling Sounds like the compressor is trying to click on but then stops. Makes a funny noise.
The freezer side of the side by side door refridgerator is not freezing. It is dripping water from the ice maker opening, with no ice being made. Help
Posted on Oct 24, 2008
    Problem Solver:
  • 5 Answers
You probably need to change the compressor, but first try to change the starting relay for one whith the same capacity
Posted on Jun 29, 2008
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
Delonghi PAC AN140HPEC clicking noise.
1) test the mounting pads and bracket for worn
2) The compressor and motor are powerful device for make enough noise.
3) Try to adjust it very well in the frame windows, for vibration.
God bless you
Jun 22, 2012 | Heating & Cooling
No AC, then recharged, now compressor makes on/off clicking noise while running with AC on
This still sounds like low pressure. If you re-charged a system that was low, and didn't pull a vacuum and evacuate the system first, then you still have air in the system, which is causing the compressor to cycle on and off.
Jun 07, 2012 | 2006 Ford Taurus
WHERE A PLASTIC PIECE PULLS IN THE COMPRESSOR MAKES A CLICKING SOUND LIKE GOING OFF AND ON, SOME TIMES IT MAKES A SPARK INSIDE THE PLASTIC CONNECTOR....
The freezer control will normally make a ticking noise when starting and stopping the compressor. If it is clicking on and off in abnormally short intervals, you could have a component failure that needs a technician's attention.
The overload on the compressor will also make a clicking noise when it trips. If this overload is tripping, the refrigerator and freezer will normally not be cooling properly. This lack of cooling may take several days to appear.
Jan 18, 2011 | Maytag MZD2766GES Side by Side...
UNIT (ABOUT 4 YRS OLD) STOPPED COOLING FREEZER AND FRIDGE AND MAKES A BUZZING NOISE ABOUT EVERY 5 MINUTES.
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Dave
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Windows ac kicking and click noise
sounds like the compressor is wearing out
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
When compressor clicks on it makes funny electrical humming sound and then makes click sound and does not get cold. the compressor feels hot.
sounds like a bad compressor to me, you should have 5 yr full warr on compressor, if over 5 years you can try to replace the overload relay assy attached to the side of the compressor
Nov 11, 2008 | Amana Refrigerators
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Noisy compressor
im sorry to inform you that you may have a bad compressor that needs to be replaced. try checking the potential relay located at the side of the compressor and also check the over load relay at the same spot where the potential relay is. be carefull, the compressor is very hot. if they are ok, then you have a bad compressor.
Feb 25, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
190 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
