Hatachi 53uwx10a picture out of focas /words are also double and a yellow line about 10 inches thick sloops down from the top along the top of the tv
I replaced the ic's on the video convergence board ,wasnt hard . they were STK392-110 amplifiers , they had no heat sink paste on them ! everything else checked out fine
Posted on Jul 03, 2008
My 64" LCD picture has
My first question is, do you have an LCD PROJECTION (about a foot thick) or a standard LCD (couple inches thick).... If you have an LCD PROJECTION they have something called an OPTICAL BLOCK and far to many times, these blocks wear out, and change the color of the screen to a yellow green.
Depending on the age of the tv's some companys have given extended warrentys because of these blocks, but I do not pretend to know Mitsubishi's return policy.
Anyhow. the page you are looking for is
Go down to the word DOCUMENTS, click it, and put in your model number.
I hope this helps
Nov 25, 2010 | Mitsubishi Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
The TV picture is not focused.Is there a way to focus it?
Yes,remove the back of will see a red wire leading to the picture tube.Follow that wire down to the board.You will see 2 controls on the one is focas,bottom one is screen.Turn focas control until picture is clear.
Oct 08, 2009 | RCA F19262 19" TV
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Pictures not lined up and angled
Sounds like your convergence is just out. First make sure the mirror in back is pulled out completely (if you have that model). Otherwise, there is a convergence feature on the menu that should fix it all.
Jan 03, 2009 | Philips 60PP9202 60" Rear Projection...
Horizontal lines across the top 3 inches of picture
what line started? from Left to right? or from top to bottom?
Nov 28, 2008 | Philips 32PT6441/37 32" TV
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Hi there!
Sounds like convergence Amp to me. Refer to a repairer if you are not sure. Good luck,JUS004
Jan 11, 2008 | Mitsubishi VS-55707 TV
Tv help!
When you have the back off, look for the flyback (high voltage) transformer. This is the part that has the thick red wire protruding from its top which attaches to the top of the picture tube with a suction cup. On the flyback there are 2 controls, the bottom one is screen and the top one is focus. Turn the bottom control (screen) down (counterclockwise) until the white lines go away and the brightness looks normal. Then turn the top control (focus) until the picture is nice and sharp. If the F connector has been pulled out and the TV has RCA (red, white, yellow) jacks, use those jacks and set the TV to INPUT.
Aug 13, 2007 | Zenith A27A11D 27" TV
Televison & Video Logo
Top Televison & Video Experts
