Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Whirlpool dishwasher du1100 xtpq8
I have a problim with my dishwasher. when i put the plug in the outlete, in a few seconds the normal key starts blinking and no keys work except for stop. when i push the stop key it starts blinking.
and this is troubleshooting guide
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
Dishwasher makes a high pitched noise when washing..sounds like the pump..?? DU1100 Whirlpool Quiet partner II
Posted on Feb 11, 2009
Turned on the 1 hr button and it did start but after a few minutes it stopped. None of the controls are lit and the water is just standing in the bottom. What do I do to get it started again?
If it fills with cold water, it will pause and try to heat the water... if there is no heater function, it will never achieve wash temperature.
To invoke the Diagnostics Cycle, perform the following while in standby:
? Press any 3 keys in the sequence 1-2-3-1-2-3-1-2-3 with no more than 1 second between key presses.
? The Service Diagnostics Cycle will start when the door is closed Whirlpool Dishwasher High Limit Thermostat WP661566 , Whirlpool Dishwasher Heating Element W10518394 , Whirlpool Dishwasher Control Board W10751502
Jul 12, 2016 | Whirlpool Dishwashers
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Whirlpool DU1100 quit running
Check the breaker and make sure it has not tripped. You should also check the GFCI in the kitchen area too.
Jan 28, 2013 | Whirlpool Dishwashers
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
I need a heating element (i think) for my whirlpool quiet partner 1 dish washer, but i need the model number and I dont have it with me, do you know the part number for the heating element that I need or...
Your Whirlpool Quiet Partner 1 should have its model number inside along the left side. Mine is DU1010XTXT1. Your heater part is original Manufacture # W10518394. Can be purchased for about $38.00 at
http://www.partselect.com/PS8260087-Whirlpool-W10518394-Heating-Element.htm?SourceCode=3&SearchTerm=w10518394
or order an after market heater element part # AP5690151 for about $33.00 at
http://www.appliancepartspros.com/whirlpool-heater-w10518394-ap5690151.html
Hope this helps!
Apr 04, 2011 | Whirlpool Dishwashers
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Normal cycle light flashing
If its the ormal led flashing that is normally caused by a stuck key ing the key pad. Might try unplugging and plugging back in but sounds like you need a new touchpad.
Mar 11, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
DU1100 XTPS DIshwasher
I would make sure that the lever on the dishwasher body is not bent in any way. If it is you can straighten it out and then make sure the door close's properly. But for being 3 months old I would give whirlpool a call and have them send a repairman out. There will be no charge to you seeing its under there warrenty.
Jul 21, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
776 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
