Release the chain brake and remove the bar and chain. Clean the engine area where the bar fits to, then start the engine--oil should ooze out of the side port. In that case, clean the bar drive-end small oil passages that run from the large holes out to the chain groove on each edge. These passages commonly plug with sawdust/dirt over time and cause greatly reduced oil to the chain/bar. When all is back together, run the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil after a moment or two of running. Adjust the oil volume screw to achieve that result. Hope this helps!
