My Haier HW-C1460TVE-U washing machine was installed this morning did the empty cycle first then did a load of towels worked perfectly did another wash Err code Unb came up. Got sprit level and checked adjusted legs so it was level. Did a 90 degree wash for 2hrs - Err code again Unb washing not spinning coming out wet through. Any ideas only had it since 8am this morning.
  • 6 more comments
  • marvinsmate Jul 15, 2008
    Hi, did you solve this? I have same washer and same problem. Thanks
  • lyn735 Jul 20, 2008
    We've got the same problem too with our newly bought Haier HW-C1460TVE-U....the machine is on a level surface, but it doesn't matter if its completely full, half full, or even empty - the machine refuses to spin and clothes come out soaking.
  • duranlebon Sep 18, 2008
    Think the only way to solve this problem is to demand a refund! Engineer called today as we have same problem. (unb message and machine not spinning). I put machine on after engineer had fitted a new circuit board and said machine ok, machine will not work at all now, err 7 message on screen. Told comet I want a refund, will keep you informed.
  • Anonymous Sep 21, 2008
    had the machine for 4 months+ all fine then suddenly it wont spin checked all normal things filter,drain pump etc,the fault only appears when the cycle is finished then it displays end/unb and the clothes are still wet
  • pattersnic Oct 16, 2008
    Has any one got any updates on their pproblems as I have the same problem?
    thanks,
  • Anonymous Feb 01, 2009
    I have exactly the same problems as everyone elas with this machine. Any ideas how to fix yet?
  • Pauline Chatburn Apr 05, 2009
    I have the same problem with this machine except it only happens when there is a small amount of washing in. I thought unb meant the washing was unbalanced in the washer but I dont know.
    Please let me know if this problem is solved.
    Thanks.
  • karenlawford Apr 28, 2009
    Am on my 3rd haier now. Still the same problem wont spin out half loads , bedding, towels etc. waste of mone. Comet wont refund.
  • 3 Answers
Have been to one of these machines today. UNB will still show even if the machine is empty. I think the feedback amplifier on the main PCB is at fault. If I have any luck with it I'll post another message
Posted on Jul 07, 2009
What a waste of money!!! I had two due before I told them I wanted a refund. Don't waste your money on HAIER!!!
Posted on Aug 06, 2008
    Problem Solver:
  • 5 Answers
I called comet they installed a new chip board un balanced means the loads are too heavy for the machine if u aint got warrenty take it back and demand a better washer preferably not haier
Posted on May 15, 2009
Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
Nov 08, 2013 | Haier Washing Machines
It is not draining the water out it is a haier hw-c1460tveme-0
Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
Feb 12, 2011 | Washing Machines
Machine won't empty
It will not spin if there is water in it.
Locate the filter, which should be at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Hope fully this will solve the problem.
Jan 21, 2010 | Bosch Classixx WFC 2465 Front Load Washer
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
I just purchased a Hotpoint WDL540, I had it installed on Saturday. On sunday I did the test cycle, which worked fine. When I put a regular load in, it wouldnt go through the entire cylce (wash, rince,...
If I had to guess...I'm thinking that you may not have shut the door to the machine. The safety feature was engaged. This might let the timer run the cycles but would have prevented the agitation and spin functions from working. Not the problem...get the manufacturer on the phone
Dec 01, 2008 | Washing Machines
Haie hw-c1460tve
Err2 means "Drainage error. water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for a blockage. If error still exists, please contact the maintenance personnel." This is what it says in the instruction manual
Feb 20, 2008 | Washing Machines
Westinghouse Top Load Washing Machine
Possible your outlet filter is blocked, it need periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first. Well, you have a record of sorts, 30 years!!
Jun 13, 2007 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
1,846 people viewed this question
Top Washing Machines Experts
