Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore doors getting air vaccum and will not open right away
Has anyone had a kenmore frig where when you open the freezer for 30 secs then shut it, it must then pull air inside of it and i cant open the freezer or frig door for like 30 secs until the air pressure equalizes? Is there a sulotion to this
  • 481 Answers
  • that is just a sign of a very cold freezer and a good sealed refrigerator.
  • if you don't like it then turn your freezer down so it wont get so cold.
Posted on Jun 29, 2008
Ice in bottom of side by side Kenmore freezer side
Make sure the doors are closed tight - freezer door may open a crack when frig side closes.
If door is tight, make sure the door gasket makes a tight seal. Often they need to be cleaned (409 is my favorite) or they get twisted. They also sometimes come away from the door in spots. Pay attention to the bottom seal which you usually don't notice in daily use.
Nov 03, 2017 | Kenmore Refrigerators
Kenmore side by side freezer not freezing
I have had that problem when my Kenmore frig was surrounded by too much stuff that prevented air flow to the coils. It was also a problem when I had it on carpeting. I put a wood panel underneath the whole frig and cleared away all the clutter.
Mar 22, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator-model#106.74254400 freezer is working fine, refrig. will not get cold. Any ideas?
the damper vent door between the 2 compartments is not opening to let cold air in from freezer to refrige,also make sure fan is also running to push cold air through this door,a lot of times its either frozen shut from moisture or the door shaft breaks and it jams shut or the damper door motor goes bad,its a 106.xxxxxxxx model so whirlpool produced it for kenmore
Apr 11, 2011 | Kenmore Refrigerators
Freezer Door will not stay closed, opens about a half inch after removing pressure.
You can try and adjust the front legs of the frig raising the front about one or two inches. This will but more pressure on the door seal.
Sometimes if you slam the frig door the freezer door will try and open. Tilting the frig back will help solve this problem.
Dec 31, 2009 | Kenmore Refrigerators
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
My fridge freezer comprises of the top one being the fridge and bottom is the freezer. its Zanussi by Electrolux . problem is the fridge is not functioning and its warm (its not cold at all) but freezer is...
It sounds like the fan in your freezer is not working so it can't get the cold air to the frig or your coils are not defrosting and it is stopped u and cant blow air into te frig, One way to check if you hear the fan and know that it is working open the frig and put your hand up near the vent to see if you can fill cold air if you can't now open the freezer door if you can feel the cold air or more air r coils then you could before then your coils are stoped up the unit is not defrosting.
Apr 03, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Trio refrigerator (#596.76502500) is not working. The temp is 76degrees. The freezer seems to be working fine. I have switched it off at the circuit breaker and restarted it after 10 min. The...
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
Aug 04, 2008 | Kenmore Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
87 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
