Question about Wacom Intuos3 Graphic Tablet
Wacom pen stops working
After sitting a few minutes, my pen stops working. I believe it's an Intuos 3 4x5 or whatever the small size is. I use it on my lap so the label has worn off
  • ernestww Sep 23, 2008
    I have the same problem. Intuos3 9 x 12" running on XP. It suddenly just stopped working. Wacom support had me reinstall drivers. that works for a few minutes...then it stops working again. It had been working for two years without an issue. Tried different usb ports, uninstalling drivers reinstalling different versions all the same effect...works for a few minuts then stops. Wacom email support suggested uninstalling my mouse drivers and using the wacom mouse. This sounds stupid as prior to this week it had happily worked with my logitech mouse...so wtf?!
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
SOURCE: New Wacom Intuos 6x8 Graphics Tablet with a Serial connection (using a USB converter) work with Vista?
Searched for ages to find a driver for my giant wacom (UD-1212-R) on Vista 64. As of this moment there isn't one, and it looks like they are not even going to bother. But if there are any geniuses out there........
Posted on Nov 05, 2008
SOURCE: how to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Posted on Feb 22, 2009
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: Wacom Bamboo Fun Pen isnt working correct
I think you dropped the pen on its tip and broke the little ferrite sensing core.  You can try to repair it by gluing the core back together - it worked for me.  For detailed instructions on how to do it, go here: http://wishidknownthat.blogspot.com/2009/04/fixing-wacom-bamboo-pen.html  or you can try to swap the core for the eraser and the tip (more involved - you would need to be very good with a soldering iron to attempt this).  Either way - it's unfortunate that the pen is so fragile and that the user manual doesn't really warn you of this.
Posted on Apr 05, 2009
Where can i get a wacom bamboo tablet?
You can buy them new from places like Amazon or directly from Wacom. Just to confuse you more-- it used to be Bamboo, Intuos, and Cintiq. Now the entry level tablets are the Intuos, the mid-level has become the Intuos Pro, and then the Cintiq.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=wacom+bamboo
https://store.wacom.com/us/intuos-pen-touch/
Feb 25, 2015 | Wacom Bamboo Computers & Internet
Does the Wacom Intuos2 Classic Pen (xp 300e) work with the Wacom Bamboo CTL 470 tablet?
From what I read on Wacom's site, they are NOT compatible.
The Bamboo use a stylus that is different than the nib pens that the Intuos use. The stylus for the Bamboo is more like the stylus you can purchase for smart phones. The Intuos pens are pressure sensitive and have different nibs you can use for different effects and feel. You can go to their website and look for compatible pens and stylus' for your specific tablet.
Aug 02, 2014 | Wacom Intuos2 Classic Pen (XP-300E)...
Wacom Intuos Pen Proximity Issues.
have you solved the problem?, because the same thing happened to me :S
Jul 13, 2010 | Wacom Intuos2
Wacom intuos3 pen is not working
A few hours ago Wacom released a new driver 6.1.2-5 for the Windows 7/Vista/XP operating systems. I was having the same problem. Hopefully this will be a permanent fix!
http://www.wacom.com/downloads/driver-detail.php?id=200
Nov 19, 2009 | Wacom Intuos3 Graphic Tablet
When I go into certian programs like inkscape or the newer Gimp my wacom pen wont draw,but it will select items. yet if I use an older gimp 2.0 it works fine I have the intuos 3 ptz -431w actually it did...
I didn't solve it myself (a lady named Linda deserves the credit) ... but the solution at the following URL worked for me when I encountered the same problem with inkscape0.47 and intuos 4 wacom tablet pen:
http://inkscape-forum.andreas-s.net/topic/200534
Thanx, Linda!!!
cheers
zookumar
Aug 07, 2009 | Wacom Intuos3 Graphic Tablet
Wacom Digital Pen Wacom Intuos PEN UNRESPONSIVE My pen does not show up on the list on the programs properties.
You can contact the Wacom company on their website. Maybe they can replace the pen.
www.wacom.com
Mar 02, 2009 | Wacom INTUOS Pen w/Stand
Intuos pen
Yes, download the new drivers at the Intuos site
Aug 14, 2008 | Wacom Graphire Intuos Pen (GP300ESE)...
Intuos 3 Keystroke and Touch Strip not working properly.
solution-------just try new drivers.
http://www.wacom.com/downloads/drivers.php
Jun 26, 2008 | Wacom Intuos3 Graphic Tablet
Wacom tablet stopped working, blue light on.
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Jan 15, 2008 | Wacom (PTZ930AC) Graphic Tablet
Wacom Intuos3 Graphic Tablet Logo
143 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
