Where is the compressor relay located on the condenser
Trying to locate and test compressor relay on the condenser
  • 165 Answers
That I don't know, sorry
Condensor is the outdoor unit.
Posted on Jun 29, 2008
Stopped working. clicking sound when it wants to start up. Is it the compressor or the relay switch model 8 yrs old old.
You.have to check if the compresor is working or damage. Try starting direct the compresor, Generali should be the electric part outside the compresor just change at the electric parts and should work. If you send a picture of the position on the connectors I will help you to try the compressor
May 29, 2015 | LG LFX25960ST Stainless Steel French Door...
Tip
My refrigerator is not cooling, how can I fix it?
It could be one of several problems -
1) Failed compressor relay
2) Failed compressor
3) Failed component in the defrost system
4) Bad door gaskets
5) Failed door light switch
Questions to answer -
1) Is the compressor (large black domed item with three tubes (one stubbed) at the bottom back of the frig.) warm or hot? If cool, then you could have a failed relay inside the compressor enclosure. Unplug the refrigerator from the wall, locate where the wires go into the compressor terminal box. Remove the clip holding the cover, and pull the relay off the compressor. Inspect for evidence of burning. Replace if necessary and reinstall all covers. You should always hear a clicking sound when the compressor tries to start. If it does not start, and you hear it click again a few seconds later, then it's likely you have a failed compressor.
2) Was the condenser fan running? The condenser fan pushes rejected heat away from the condenser coil. If it's not running, it's hard on the compressor, and the refrigerator does not cool.
3) Was there thick ice buildup inside the louvers of the back wall of the freezer? Heavy ice buildup here is an indication of a failed defrost control or heater and requires further diagnosis to determine the problem. A knowledge of use of a volt-ohm meter is required, along with a willingness and ability to do some mechanical and electrical dis-assembly and test.
4) Was the fan running inside the freezer? Freezer fan should run when the compressor is running, but not during the defrost cycle (or it would slightly heat up the refrigerator.).
5) Look up my "Tips and Tricks" article on testing your door gaskets.
6) Open the door slightly and look inside as best you can. Is the light on or off? Continue to open the door until you see the light go on to confirm the light switch is working.
Following each of the above steps may not help you fix your unit, but will give you an indication of things to look for and describe when you post a request for help when trying top fix you refrigerator.
on Dec 13, 2009 | Refrigerators
Ice machine not making ice
You will have a 60-90 fill cycle, then circulate, then another 60-90 fill, then on to ice making. When Ice making starts all remaining functions come on, such as the condenser fan, and compressor. Check for these functions after the initial fill/rinse/fill has finished. if the condenser fan comes on but the compressor does not, you very well may need a control board located behind the on/off switch panel. With constant heavy loads/usage, and or a dirty condenser coil the compressor relay solder joints often become weak and short open on the board, this can sometimes be fixed by just cleaning and re-soldering the relay joint on the board. Pleazer Appliance...
Feb 02, 2014 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool / Armana Side by side Fridge Freezer model sgd521sbw just stopped cooling
Sounds like the overload, Start Relay 67006453 is defective.
I am having trouble finding thesae parts in stock so you may need to get some local help. I noticed that your model has 220 volts ac what country are you located? I recommend that you also do a compressor windings test as below to insure that the compressor is worth buying the start relay components. Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Mar 03, 2013 | Whirlpool Refrigerators
Is there anyway to test start relay for a freezer
Hello - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 30, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Asd2522wrb04 amana side by side refrigerator. clicks like it is coming on. then goes off. nothing freezes or cold. Why?
I believe what is happening here is a defective start relay and overload. Right now I would pull refrigerator away from the wall and unplug. Next remove the cover over the compressor feel top of the compressor and if it is not possible to keep your hand there from heat tells me the compressor is trying to start. Keep unplugged until replacing the Start Relay Kit below.Most times the compressor that begins to do these symptoms can be fixed by replacing the=>
W10189190 Relay and Overload Kit
These parts can be found by removing the rear cover near floor and then pulling the cover on the side of the compressor. Click Here=> ASD2522WRB02 Unit Parts In that photo is a compressor top left of photo. Number location 13 is the cover of the part I am talking about and location 12 in that photo is the start relay and overload. If you have trouble I will be here to assist you, Thanks Sea Breeze
Sep 26, 2011 | Amana Refrigerators
Air conditioner relay location 2004 passat
hi,
the a/c pressure switch is located to the left side of the condenser radiator, as you stand in front of the vehicle. you may have to remove the bumper in order to get access to this switch.
there are 2 relays dealing with the a/c , numbers 16 and 17, on the relay plate at the drivers knees, the plastic panel will have to come down. 16 is the clutch relay and 17 is a/c control module.
hope this is of some help
Jul 28, 2010 | 2004 Volkswagen Passat
2000 grand caravan 3.8 Condenser fans not comming on with a/c ...fans do cycle with engine temp compressor is engauging and a/c is trying to work but gets hot fast with no ..... fan working
Check under the hood in the fuse/relay panel. Lift the cover and look inside the cover for the correct location for the fuse/relay controlling the cooling fans. Either the fuse will be blown or the relay is bad. Use a test light to check the fuse for power on both sides,if you have power on the fuse then the relay has gone bad. Hope this will help you.
May 23, 2010 | 2000 Dodge Grand Caravan
My Magic Chef refrigerator model CTB1722GR is blowing nothing but warm air. Compressor failure???
Good day,
Four possibilities.
1. The condenser cooling fan motor located on the bottom back of the machine between the compressor, and box condenser has failed, and needs replaced. It should be running if the fan in the freezer is running.
2. Loss of refrigerant or a restriction in the system. Testing limited to a qualified tech only.
3. The combo relay overload mounted on the compressor( under a cover) has failed. Most appliance parts houses will be glad to test them for you.
4. Locked compressor. Tech only solution.
PS. If the machine is less than 5 years old, the compressor is under warranty. Contact your selling dealer.
Thank you for using FixYa
Dec 27, 2009 | Magic Chef Refrigerators
Maytag msd2652keu side by side compressor gets hot shuts off and unthaws freezer i unplug 4 a few hours plug in and works 4 a couple weeks any idea
Check to make sure condenser fan is working (this is the fan located near the compressor). It should be running at the same time the compressor is running. If it isn't, make sure there is power to it by testing with a voltmeter. If there is, replace the fan. If the condenser fan is working, clean the coils and check the evap fan.
Jun 25, 2009 | Refrigerators
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
