Question about Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961AVZ Will not start ...I get a momentary flicker of power about every 3d or 4th time that I flick on the power sw. Outlet is fine / Plug looks good / chord looks good / I see no obstructions ........Would appreciate any helpful thoughts ....Trying to get Mom's Eureka 2961avz back up and running. Thanks
  • Janice Tefft Feb 09, 2009
    I have the same problem. Would have to play with the switch to get it to come on then the switch broke and now can't use vacuum. Is the switch easy to get to if I take it apart?
    Same problem. switch would spark while trying to turn it on, then it went dead altogether. I can feel the switch let loose and won't turn on or off now.
    Problem Solver:
  • 13 Answers
CAREFUL! This is how my problems started. The cheap switches (and wiring) Eureka is using in some models, especially my model) should provoke a lawsuit imo.
Here's my story, just in case it might help. Mine started with a problem very similar to your, i.e. flickering. If you take apart your handle (top part where switch is - two screws), you might see some fried wires. Anyway, my story ...
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Posted on Jan 30, 2010
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=538511&thid=720558
Eureka 2961AVZ
Posted by Joanschmuck on Jun 29, 2008
Will not start ...I get a momentary flicker of power about every 3rd or 4th time that I flick on the power switch. Outlet is fine / Plug looks good / cord looks good / I see no obstructions ........Would appreciate any helpful thoughts ....Trying to get Mom's Eureka 2961AVZ back up and running. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a bad switch or the worst scenario would be a bad motor and or armature, and the armature is almost the cost of the new motor, so I would replace the motor, but check the switch and the cord because sometimes the cord looks good but there might be broken wires inside the cord that you can’t see. If the vacuum is less than one year old the motor would be covered under the factory warranty if one year and maybe the switch as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
Looking for the roller part number for Eureka 2961AVZ. The ball bearing on one of the side broke on the existing roller.
You should be able to find the roller you are looking for at this URL:
http://www.vacuums24x7.com/eualseup29se.html
Paul
Oct 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
The vacuum went its on and running a faint burn smell
That means that you need to change the belt. Here is the belt you need and the manual which has instructions:
Eureka 2961AVZ Belts
Owner's Manual
Jan 03, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Beater bar does not rotate
That means that you need to replace the belt. Here is the belt you need and the manual which has instructions:
Eureka 2961AVZ Belt
Owner's Guide (3.4 KB download)
Dec 27, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Brushes do not spin when it is on low carpet you have to have the knob on high carpet for it to work.
That means that the belt is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet. The lower the setting the more resistance. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Nov 19, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
LOUD
You might need to change the drive belt. Here is a link to the belt you need and to the manual:
Sep 16, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Burning smell and not picking up dirt
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Jul 02, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
179 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
