HP Laptop (with Windows XP) that won't boot up properly.
I opened up my laptop to get a look at the power jack. In doing so, the fan became unplugged, but I plugged it right back in. Couldn't get the cover off the bottom of the laptop (aside from the cover over the fans) so I closed it back up and didn't even get to get a look at the jack.
When I went to reboot, I got the message: "we apologize for the inconvenience but windows did not start successfully, A recent hardware or software change might have caused this, etc.
With some assistance from the Geek Squad, I chose to restart with last good confirguaration, or something to that effect. Then it restarted. When I got home, I wanted to make sure the system settings were just as they were before it went squirrely. So I did a system restore to a point before the fan became unplugged. When it tried to restart, it konked out. After I waited 10 minutes I was able to re-boot it and the system restore was complete.
However, since doing that, a booting problem occurred that does not seem to be going away. I can shut it down, but it won't reboot fully *right away*. If I do a restart, I see the HP screen come up, but then it goes to black (laptop is still powered though). If I shut it down and wait five minutes, it boots up normally.
Any idea what the problem could be? I wasn't having any type of problem like this before the fan became unplugged.
Thanks.
-Samantha
    Problem Solver:
  • 13 Answers
Check you havent accidently knocked the RAM.
You may have put the the fan in the wrong plug.
e-mail me photos of the mother board or wherever the fan was.
completleywacked@gmail.com
Posted on Jul 01, 2008
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
HP Pavilion dv6-7010us won't boot up
Hello.The most common reasons for this issue are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The
power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Oct 27, 2012 | HP Pavilion dv6-7000 dv6-7010us B5S11UA...
Won't go into windows XP
What happens when you press the power button?
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 05, 2012 | Computers & Internet
HP Pavillion DV8000 Laptop won't boot.
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
Click here for more information
Nov 27, 2009 | HP Computers & Internet
Hello. when i plug in my hp dv5220us laptop it sounds like the fans running all cenyer lights on but power button will not turn on. same with battery
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | HP Pavilion Dv5220us Notebook
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
Get restarted again and again laptop
Problem 1: Loss of either the power supply fan or the CPU fan can create that problem.
Problem 2: Windows XP may not have the SATA driver on the setup disc for your machine thus the install doesn't "see" a drive. There is additional info at this link (at the HP website) about how you can integrate the drivers into your XP install.
You shouldn't need to load Vista again but most likely you could use a dual boot for your machine if you wanted to. For the fan issue you may want to place it into service if you aren't comfortable taking apart a laptop for checking or replacing a fan. Generally the parts can be sourced online for your machine (and usually cheaper than through a service facility) but it comes down to comfortability with the replacement procedure when deciding to put it into service.
Mar 04, 2009 | HP Computers & Internet
Hard Drive with password protected.
I had the same problem. This is how I reset my password on a compaq or hp nc6320.
1. unplug the power cord
2. unplug the battery
3. take two screws from the ram cover on the back of the laptop (see youtube for this step)
4. open the keyboard
5. unplug the cmos battery cable (very easy to do)
6. plug power cable and turn on the laptop
7. laptop would erase passwords.
8. put everything back together.
A pleasure to help.
Javier Blanco
Mar 24, 2008 | HP Compaq nc6320 Notebook
Boot up problem
possible that a static discharge occurred during your solder work taking out sensitive board parts...was your grounding wrist strap on and were you properly grounded?
Jul 22, 2007 | Compaq Presario 1200XL104 Notebook
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
