Question about Bose Lifestyle 28 System
Dvd issue sorry, but I need additional help. How exactly do I find this setting
  • landaiche Jul 26, 2008
    This is not a solution at all
Every time i change the dvd settings from tv to dvd or vice-versa it just turn off my tv set
Posted on Jul 24, 2008
Sanyo tv and Sony DVD player sound issue
If you post this query in a forum dealing with tv related issues, someone may be able to help you.
Apr 28, 2017 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
We have a Philips DVD Recorder a Freeserve Digital box and a TV. Since adding the DVD Recorder we cannot tune in Freeserve at all and DVD's play only in black and white. Help Please. ...
Hi Jack,
And if you remove the DVD Recorder, everything is back to normal?
Initially, I would suspect that your DVD is set to PAL system and not to NTSC (or could be the other way around). Could you pls post back with the exact model number of the Philips DVD Recorder?
Additionally, could you pls detail how the Freeserve Digital box is connected to the Philips DVD Recorder and then to the TV? Pls indicate if you are using Video IN/OUT, S-Video, HDMI, SCART, RF IN/OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
I incorrectly entered PAL in video format setting now screen is stuck and says change resol utio n but can not change it need help!!! protron pd-dvr100 dvd recorder
I'm sorry for the difficulties you're experiencing as the Video output settings on the DVD Recorder is set incorrectly. Please perform a power resetting by following the below steps and check the operation.
To perform power resetting, unplug the DVD Recorder from wall outlet for more than 5 minutes and press and hold the Power button for more than 15 seconds. It will discharge power from all circuit and move the Recorder to factory default.
Thanks for understanding. Please let me know if the issue persists.
Nov 23, 2011 | Protron PD-DVR100 DVD Recorder
Lost my manual. Displays Error Parental and will not play movie. I have watched previous movies but don't know their rating. This movie was PG-13. I don't think I ever set any parental controls...
hi, I tried to find you a user manual for you to solve the problem but I failed... sorry but without user manual it is hard to propose a solution for your problem since it is spesific issue on that model.. I only recommend to you to go to "MENU" and scrool down on the sub menus to find out a control for this issue that you can alter..... Additionally ,Here is some information I found out about Protron company:
Protron and Spectroniq are the same company. I just visited the Protron web site "www.protronusa.com" it is dead and it has not been updated since 2007. I believe the company is no longer in business and will doubt if you will find a Protron Service Center. If and when needed,You are very lucky to find a repair shop that will attempt to work on the DVD , most will not. The internet is plagued with issues with protron products .
http://www.epinions.com/reviews/Protron_PD_800
by the way based on google search ;" PROTRON " is being sued by " PROTON " for name brand name -copy right infringement.
Hope this helps! Take care and please Remember to rate/vote for me to continue for Helping out the Community :)
Thanks
Jul 01, 2011 | Protron PD-800 DVD Player
My check engine light came on so I took to an ASE certified mechanic and it came up TCC code but didn't say anything else. The mechanic checked the transmission fluid and all looked clear. The van shifts...
The exact code he pulled would be helpful. Does it shift into overdrive? It could be an electronic or mechanical failure which is why I would need the exact code to help you better.
Mar 09, 2011 | Chrysler Town & Country Cars & Trucks
The DVD player on my 05 Dodge Grand Caravan quit working. 3x3 White lights flash (on the DVD changer) and when I select the DVD option on the main console I get the message "Error". The Radio/Cassette and...
I also have a 2005 Dodge Grand Caravan with the exact same problem. From an internet search (how I got here) it seems this is a somewhat common problem.
This issue does not involve a fuse as the changer has power and operates as evidenced by the sound of the changer cycling and the lights are on. Any additional help or any resolution found would be helpful.
I do know from internet research and my experience that this problem is brought on by disconnecting the vehicle battey such as when you install a new battery.
Jeff
Virginia Beach
Feb 20, 2009 | Kenwood Excelon KVT815DVD Car DVD Player
Recording from VHS to DVD
Appreciate the direct "Ask Me".
To my knowledge, a KLH DVD8350 is only a player, it has no recording capabilities, sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | KLH DVD8350 DVD Player
Question
To my knowledge, a TruTech PVS12701 uses a Lithium-Ion 7.4v 2500mAh battery. There are no exact replacement batteries for this model. Best that you can try are batteries for some other brand of portable DVD players such as those for Samsung that has the same physical dimensions and electrical properties. Another factor to be considered is the cost of the battery. In some instances, it would be more economically reasonable to purchase a new portable DVD than just the battery. Sorry.
Jun 26, 2008 | TruTech PVS12701 Portable DVD Player
Ehm im sorry
Make sure the jumpers on the HDD are set to master. Try on a different PC to see if it is recognized. Check the cables, etc..and let me know.
May 27, 2008 | Microsoft Windows Xp Home Edition Sp2...
Router setup
All -
In general I suggest getting a
First get a wired computer working
-- less complex and fewer issues, normally.
Second try to get unsecured wireless connection working
Third secure your wireless network.
Fourth where appropriate, deal with game connectivity issues.
One link that may help follows http://kbserver.netgear.com/products/WGR614.asp
use this this find the exact version of your router. Click on the appropriate support link. Under "Other Useful Documents" the contents vary (have not checked what is available under all versions) but the first document of interest should be the
"ISP Configuration Guide" which should get you well on the way to connecting computers.
For those of you with games there are
xbox instructions for some of the routers
There appear to be general game related instructions for more routers.
Because of the variability of your situations because it is unlikely you all have the same ISP I suggest you all open new issues where you - Identify the router and version, identify your specific ISP's and any additional requirements including wireless connections, game consoles or other devices to hookup if you need additional assistance.
Dec 22, 2007 | NetGear WGR614 Wireless Router
Bose Lifestyle 28 System Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
