Question about Philips 50PF7320A 50 in. Plasma HDTV
HDMI Support My Philips model: 50pf7320a/37, dose not always support the HDMI connection from my cable box. The Cable provider is Brighthouse, the cable box is Explorer 8300HDC. The error code is (GS511_HDCP_DLG).
  • vegeta42578 Jul 01, 2008
    The link you gave me is very helpful. However Philips require a FAT/DOS USB storage. Where can I get one or how can I format my PNY 2gb, my OS Windows XP.
  • 3 Answers
If this doesn't help, there may not be much hope for you.  There are some ambiguities in the HDCP protocol (rights protection for HD).  When two devices use this one will send a message to the other, it then waits for a response, lastly it responds back.  This is the connection setup procedure.  The issue is that there wasn't a specified time limit that a device must wait before assuming the connection isn't working.  This can cause you to get an error message along the lines of "your tv doesn't support hdcp"  Unfortunately, there's not much that can be done about this.  I spent the better part of two weeks researching this issue trying to figure it out.
As for formatting your usb key, you should be able to go into my computer, right click on the drive then click format.  It should give you some options as to how you want the format done.
Posted on Mar 04, 2009
    New Friend:
  • 129 Answers
Follow this link dowload the software upgrade for your tv and procced to install this can help to solve the problem
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=50PF7320A/37&scy=US&slg=AEN&searchtxt=50PF7320A
Your rating to my answer is highly appreciate
Thanks
Posted on Jun 29, 2008
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
The tv will not turn on anymore-have a blinking red light where the power green is located -is a flat screen hdtv connected to an xbox 360, tivo, and cable box. model no. 42PF9431D/37 . The cable is...
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Dec 15, 2009 | Philips 42PF9431D/37 TV
I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Dec 08, 2009 | Philips Televison & Video
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
PIP problems Philips model 42PF9631D/37.
if you have a cable box and run it thour the cable box it will not work. cable befor the cable box you can do it put a spirer on the line be for the box run one to cable box 2 to the tv ant1 ant2 that is the way you can do it.
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
Picture in Picture
Does you 9631 have 2 HDMI ports ? And are u trying to use both HDMI ports at once trying to use the pic in pic feature ? The processor might not be able to process both HDMI signals at once. Try using the tuner (a tv channel and a AV connection ) and see if you have the same problem).
May 05, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 50PF7320A 50 in. Plasma HDTV Logo
454 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
