I need to get the front panel off my Bosch Exxcel 1200 Express washing machine to clear some "stuff" from between the drums. (Curtain hooks. Thanks daughter.) I've taken off the door and removed all visible screws but the panel is still held in place somewhere as is the top (controls) panel. (All those screws removed too.) What's holding it in place? Is there a cunning trick to releasing these panels? Derek.
    President:
  • 1,462 Answers
Try another way. remove the heater - it is just held in by a 10mm nut in the centre then prise out with a screwdriver. you can then see into the gap between tub and drum and fish foreign objects out
Posted on Jun 29, 2008
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
Dec 08, 2013 | Bosch Washing Machines
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
need more info what point in the wash does it start to display the code
Sep 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch exxcel 1200 express washing machine
more info ie is it noisy is the drum turning?
Nov 29, 2007 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
