Question about Bushnell Trail Sentry 11-9200 Digital Camera
Pictures of nothing?!?!?!
I've set my trail sentry up twice now and both times when I've come back to retrieve it I have roughly 600-700 pics of NOTHING!!! I've read that the sun can affect trail camera's and their sensitivity, but the fix to that (I thought) was to set the camera view facing either north or south instead of east/west. I just returned from the area I'm scouting and again I have 644 pics of nothing. And all of the pics were taken the same day I set the camera up (last Sunday). What the heck is making the camera click picture after picture??? I live in Arizona where the avg daily temp is 98-107 degrees right now...can that have something to do with it? I don't think the camera should care how hot/cold it is as long as it establishes a set temp right from the start and then only snaps a shot when the PIR sensor detects a deviation in temp +/- 10 degrees. Is that correct? A gust of wind or the slow movement of the sun shouldn't make the temp rise or drop 10 degrees within a split second to trigger the camera (in my opinion). I'm just getting pretty frustrated because I know the deer are out there (I've seen them) I just need to determine how big the bucks are and if the area is worth hunting. The season starts in about two months (archery) and I would like to get this area scouted. Any help/tips would be greatly appreciated.
  • 1 more comment
  • djputnam Aug 19, 2008
    I have the same problem. Hundreds of pics of nothing but grass and weeds
  • djputnam Sep 18, 2008
    I have the same problems. It either takes hundreds of pics of nothing or does not record anything. I suggest making a door stop out of it and buying something else.
  • sheriholm Nov 06, 2008
    We have the same problem...and a few more problems, too. The timing on the camera is set to slowly to capture the animal. The camera senses it, but by the time it snaps the picture, the animal is gone. Out of 45 pictures I got one shot of the back end of a deer as it was almost out of view. I also have problems with the memory cards.
    Another problem we encountered is that the camera works for awhile, then just decides it's time to quit. We set it up in our home trying to find any come of trend, or rhyme or reason to this problem. We haven't found any common cause that it could be.
    This is the 2nd Bushnell camera we purchased. The other was a binocular camera. That was a piece of junk, too. It works fine as binoculars, but the camera component is just about worthless.
Had the same problem
is the tree you mounted it on too small?
the wind was blowing the tree i had mine mounted on and moving enough to trigger the camera
i cut the tree of about five feet up and havent had a problem since
also are there any branches in the way that may be blowing in the wind?
Posted on Sep 17, 2008
  • realtree290 Jul 11, 2011
    when ever you put it out, make sure its faceing down the deer trail, that way it has more time to take a picture.
My camera takes pictures and there.s nothing on them
Maybe they are being tripped by moths or other flying insects.
Jun 20, 2016 | Simmons 119236C WHITETAIL TRAIL CAMERA...
I got my Bushnell Trail Sentry Digital Trail Camera and the code does not work so what is another code.
the first time the camera is used the code should be 0000 unless previously changed,try removing and reinstalling the batteries,this hould start your set up again.
press and release the power button and wait for 4 H's,"HHHH" to appear,this may give you another chance to use 0000 or whatever you chose as your password.press enter after each digit,then press enter again.the indicator should display PASS.if it displays ERRO then it is the wrong password.there is a password recovery service provided by Bushnell at 1-800-423-3537 and press option 2,you will need to provide your serial number to the representative.
hope this helps.
Jan 09, 2011 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry camrera will not accept any code
If the Bushnell Trail Sentry 11-9200 is turned on without an SD Card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
The camera will not Make sure the power is off before installing or removing the SD Card. If you forget, you need to do the reset procedure above.
Buy Name Brand Trail Scouting Cameras here.
Feb 07, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Model 11-9305 trail cam only works one day after setup. takes good pics only for one event
The problem with the Bushnell Trail Sentry 11-9305 is that it is a power hog...I got this camera for Christmas 2009 and it had 2500 milliamp hour batteries with it and no solar panel...I have lots of coons and rabbits coming to the feeder and had up to 50 pics/night...The batteries would only last for three days or so...Since then I have ordered 10,000
milliamp/hr batteries and the appropriate solar panel that fits it...
When the batteries get low, the camera shuts off....
So, the problem may be that you had some bad batteries to start with..(Only takes one)
The first thing I would do is put heavy duty alkaline batteries in it...
(You'll have to reset the day and time)
If the alkaline batteries work for several days then do what I did...Get the solar panel that is made for it and HEAVY duty NiMH (Nickel Metal Hydride) rechargable batteries...(9000 or 10,000 milliampere hours)
You can buy these on E-Bay for about $26.00 for 4 batteries with free shipping...
Hope this helps !!!
Jan 23, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Camera taking pictures of nothing.
The sensor will detect movement up to 45 feet...If there are trees blowing in the wind it will trigger the camera...
You will have to relocate the camera position....
Jan 11, 2010 | Bushnell Trail Sentry 11-9200 Digital...
How do you delete pictures from a sd card used in a bushnell trail camera
The Bushenell Trail Sentry camera does not allow you to delete pictures from the camera itself. To delete those pictures, you need to take out the SD card from the camera and insert it to an SD card reader. Plug it into your computer's usb port and delete using Windows Explorer or any picture management application.
Should you have any questions, please don't hesitate to ask.
Nov 13, 2009 | Bushnell Trail Sentry 11-9200 Digital...
My memory card is in my camera, but when it takes a picture and i put my memory card in the computer to view the pics, there's nothing on the memory card. what's wrong
A few things... Make sure that the card is the one recommended for the camera. Can you play back a picture which you have taken? That needs to be checked first. Put the card in the camera, take a picture then view it on the camera's LCD. If you can see pictures, then some thing is wrong on the computer and the way it is reading the card.
Oct 21, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Forgot password on bushnell trail sentry game camera
If the Bushnell Trail Sentry 11-9200 is turned on without an SD card in place, it may need to be reset. Reset it by pulling one of the batteries out partway, insert a new or empty SD card, and put the battery back in place. Read this Set Up Guide for instruction how to set up your passcode.
If you are looking for a replacement trail camera, or you want to buy another, go to my Hunting Supplies Website and browse through the different name brands offered for sale here. http://hunting-supplies-net.com/
Dec 09, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Black pictures at night
Yes, I've got the exact smae problem as Buckfever. no eyes, no nothing, just dozens of solid black images.
Nov 01, 2007 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry 11-9200 Digital Camera Logo
194 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
