Sewing Machines Logo
Posted on Dec 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am sewing a strip of velcro on to a piece of nylon. No matter if the velcro is on the top or the bottom it is loopy and nesting on the underside. I have the Singer curvy and have the tension set on auto. I have also turned the tension dial in either direction with the same result. Thank you in advance for any thoughts.
Michael Williams
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Dec 11, 2010
Michael Williams
Expert
Level 2:
New Friend:
Answers
55
Questions
0
Helped
21281
Points
107
As you sew, pinch the thread between your fingers to cause a false tension/drag. Does that help? if so more tension is needed. The fabric is hard, stiff and dense. you need lots of tension to set the stitch. if you need extra tension greater then the control can give, tie a piece of fabric around the arm of machine and trap the top thread under the tie to create more tension/drag. I assume the machine is threaded correctly.. top and bottom. You could also try a thick needle in order to punch larger holes in the velcro thus allowing the thread to come up easier. thats all i can do without seeing it.
  • info96649 Dec 11, 2010
    I am exited to try your ideas. I will and let you know how it goes. Thank you so much for your response!!
  • Michael Williams
    Michael Williams Dec 12, 2010
    I’m assuming the machine is correctly threaded and that the needle is not blunt, bent or incorrectly fitted
2answers
The upper thread tension seems fine but the lower tension is all loopy or broken. I'm sewing cotton fabric with cotton thread in the bobbin & upper thread. Suggestions?
it is called bird nesting and the upper thread tension is not tight enough
Proper needle thread tension is when you feel resistance as you pull the thread through the needle eye
When embroidering the underside is very loopy. I have changed the bobbin, cleaned bobbin case, checked the top threading and tightened the tension and its still loopy underneath
Not knowing your machine make/model, this is a guess. Be sure to Always Raise the presser foot when threading the top thread. This makes sure the thread is fully seated in the tension disk.
2answers
Setting tensions
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+Setting+tensions
Thread nesting on the bottom
Rethread the top of the machine with the presser foot up; sew with the presser foot down. If the fabric is too thick/too many plies, the presser foot is forced upwards, allowing the top tension to open. This causes thread snarls on the underside. See also: http://www.picturetrail.com/sfx/album/view/22521551
3answers
Won't sew stitch patterns, thread gobs up on underside fabric
it is called bird nesting and indicates that the needle thread is not tight enough
2helpful
My brother sewing machine is sewing with the bottom thread loopy and crooked. I have tried to adjust the tension, re-wound the bobbin, re-threaded the machine and still the bottom thread is not straight....
It is in your top threading, something is not right in the path. Always remember, it is the opposite of what you think. So, underside will mean that the top thread is the problem
5helpful
Bunches of threads on the bottom
You didn't give the brand, but if it's any of the older, non computerized machines, your problem is most likley in the tensions.
Loopies (tangles or nests of thread) on the bottom means upper tension too loose (or bobbin too tight).
Let's do the bobbin first...once it is set...99.9% of loopies on the underside are a problem with upper tension.
This is for bobbins that load on the front/side of the machine.. Take out the bobbin case...check the area (hook/race area) that the bobbin goes into for lint, tiny thread pieces, etc.). Now, most of this type of bobbin loads into the case with the thread going counter clockwise (when you are looking at the open side of the case), insert the bobbin in the case, and pull it through the hole/slott in the side of the bobbin case. To test for proper tension:
Lay the bobbin case in the palm of one hand, pull on the thread coming off the bobbin case. The bobbin will gently lift off your hand & if you wiggle the thread, the bobbin case should slowly drop about an inch at a time. If it's too tight, loosen the Larger (closest to where the thread comes out) screw on the side of the bobbin case about 1/16 of a turn...tiny bit...retest. Once that is done try a test stitchout. Remember to hold onto the bobbin & top thread for first few stitches.
If you still get loopies on the bottom...tighten the upper tension...it should be set between 4-5 for regular sewing.
Make sure the needle is in properly.
For a drop in bobbin...adjusting that tension is harder. You take the face plate (needle plate, the plate covering the sewing area of the machine) off and remove the bobbin case...First...look at the case in the machine...there is a little lip sticking out, usually at the bottom right corner of the open area (closest to you)...this is where you need to have the little lip when you replace the bobbin case.
Remove the case...check under it and inside the machine for lint/dust/threads & using a small paint brush (I use a childs tooth brush sometimes), clean the lint out. Now check the bobbin case for lint, especially where the thread fits..look at the inside of the case, you will see a little flat metal thing with a slott in it...make sure no lint in that slott. I use a pin to remove lint from there. Reinsert the bobbin case, rethread it all, (bobbin goes counterclockwise). Put the faceplate back on & test the stitches...still loopies with the upper set to between 4-5? Then you will remove the faceplate, remove the bobbin case & loosen the screw on the outside about 1/16 of a turn (these are usually covered in a colored coating) and retest.
I know that most home machine makers say not to adjust the bobbin..but that was back when you had one size thread...now we have many, many sizes and types of thread, so adjusting the bobbin may be needed sometimes.
Rule of thumb is:
loopies on underside...tighten upper tension
loopies on top...loosen upper tension.
But, like I said...with all the new threads..sometimes you have to adjust that bobbin.
2helpful
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
1helpful
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
