Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
We have upvc french doors, 1 seems 2 have dropped and is catching at the bottom is there any simple way to adjust this?
Yes if you have an hinge which looks like small flag there are 3 ajustment places on these you need the one pointing towards glass on tip of flag normally small white cap on front take off and use allen key and it wind back towards wall taking off the drop to it if not flag hinge you will have to call engineer ok hope this helps bub
Posted on Jan 09, 2010
Ice not dropping
The bar on the ice maker that ensures there is a catch basin underneath needs to be in the up position, after that you might check the drive motor on the dumper.
Jun 11, 2014 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
How to drop the front wheels on the refrigerator
You should be able to remove the plastic grill at the front bottom of the frig exposing the leveling screws which you can adjust without moving the frig.
Oct 13, 2013 | Liebherr CS2062 Bottom Freezer French Door...
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
May 23, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have a full length fridge and the door seems to have dropped about 1/4", causing the door to bind at the hinge and catch against the adjoining unit on the closing side. What do I adjust and how...
sounds like lower hinge loose or bent down or plastic washer wore out remove top hinge and either move bottom hinge up or shim with washer to raise door
Feb 03, 2018 | Liebherr European Right Hinge Fully...
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
Nov 07, 2010 | 2001 Dodge Durango
Fridge Door seems to have dropped
The cam risers at the bottom hinge have gone bad. Get the model number form the fresh food section and you will be able to order new ones. Not expensive to repair.
May 16, 2010 | Refrigerators
The refrigerator door seems to have dropped about 1/8 inch.
it is possible that the floor under the adjusting bolt has dropped,place a carpet protector cup under all the feet and then, using a level, make sure the unit sits square,the door may need some adjustment after this but you will see, that is a simple task.
Mar 31, 2010 | KitchenAid KSCS25FKSS Side by Side...
Garage door repeatedly drops after opening.
Remove the cover from the motor unit and check the drive gear.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Installing upvc french doors and frame
you only want 1/8 th inch all the way around the door make sure to level hinged sides and shim them in make sure to constantley look by opening and closeing door that you have 1/8th all the way around
Oct 05, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
265 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
