Question about Audiovox CDM8910US
Change Faceplate Audiovox 8900
I have an Audiovox 8900 and I want to change the faceplate. I have the faceplate and the tool, but I have no instructions on how to do this. Thanks.
  • teddiebme414 Jun 29, 2008
    Did not leave a solution.
Kuday
Posted on Jun 29, 2008
How do I change the lithium battery in my Garrison Programmable Thermostat Model No. 52-8896-6?
The front faceplate simply pulls off - no tools required. The Garrison uses 3 AA batteries. Once you pull off the faceplate you will see where the batteries go.
Hope this helps!!
Nov 01, 2014 | Heating & Cooling
HOW DO I FIND REPLACEMENT FACE PLATE & REMOTE FOR JENSON MODEL #DV2007
Here is where to get a replacement waterproof remote - http://www.jensenmarinedirect.com/jensen-waterproof-wired-remote-control.html With these marine radios the faceplate is usually the first thing to fail from water damage. Not that your is water damaged but because of this finding a used one is impossible on the net. You will have to contact Jensen for to see if they have the faceplate available separately. http://audiovox.com/jensen/ Good luck.
Regards, Tony
Apr 14, 2011 | Jensen Car Audio & Video
How to change the faceplate of a samsung s7330
  • Locate the small plastic tab on the top of your Samsung phone, located in the groove between the faceplate the main phone body. This tab is very tiny, only about one-sixteenth of an inch wide.
  • 2
    Press on the plastic tab with your fingernail.
  • 3
    Continue holding down the plastic piece while sliding the faceplate off the top of the phone. The faceplate only slides off from the top, so don't try to force it in a different direction.
  • 4
    Release the plastic tab.
  • 5
    Line up the new faceplate with the top portion of your phone then slide it downward until it latches into place. You'll typically hear a soft click when the faceplate is secure. When properly placed, the new faceplate should not be able to wiggle or slide unless you press down the plastic tab once again
    Read more: How to Change a Samsung Phone Faceplate ' eHow.com http://www.ehow.com/how_5146822_change-samsung-phone-faceplate.html#ixzz17o6dpgG0
  • Dec 11, 2010 | Samsung S7330 Cell Phone
    How to change from latch with face plate to drive in latch
    How do I mount the Face Plate on the Latch?
    Insert the latch into the faceplate opening, ensuring that the sides of the faceplate line up with the flat surface on the latch collar. Push flush with the drive-in collar. Then grasp the faceplate in one hand and the latch in the other hand and rotate the faceplate clockwise to snap in to the collar.
    Nov 24, 2010 | Weiser Lock Powerbolt 1000 Lock
    I WANT TO CHANGE MY Housing Fascia Case Faceplate For Nokia E65 with keypad
    Well you need to buy a faceplate or fascia for your Nokia E65. I receommend ebay. Looks like they are about 10 dollars for the set.
    Check out the following link for a guide video guide and links showing what is available on ebay.
    Change Faceplate on Nokia E65
    Jan 20, 2010 | Nokia e65 Cellular Phone
    Motorola RAZR V3 faceplate lens cracked
    It is not hard to change the faceplates on cell phones but you will need a special screwdriver to take the faceplate off, It looks like an octogon. I am not sure if it will fix the lens but when you look at the new plate you will be able to tell. Anymore question just giveme a shout bud.
    Jul 30, 2008 | Motorola Mobility RAZR V3
    KYOCERA SLIDER REMIX FACEPLATE INSTALLATION
    I had the same problem and I was lookin on a forum/blog on how to do this,but not many helped.I'm about to attempt to change my faceplate and I noticed when you take the battery cover off,there are 4 screws under the cover,and one near the antenna.You probably have to take apart the back part of the phone to get to the screws that are attatched to the sliding part of the phone.Its probably a little risky and tricky,but Im guessing thats how you get to the 2 hidden screws.
    Nov 20, 2007 | Cell Phones
    Nokia 5300 Music Xpress faceplate with hex tool.
    patti1010 -
    DaveRaYFTA - go to nokia.com and download the instructions manual.
    Oct 26, 2007 | Nokia 6288 Cellular Phone
    Putting on faceplate for samsung t319
    hi you best bet is go to a repair mobile shop if are in doubt to try this .
    you'll need a small Philips head screwdriver to complete the installation. To take off original faceplate, remove 2 screws located below the inside display (screws are hidden under stickers). Next, gently pry off the faceplate along the edges between faceplate and phone with a Faceplate Removal Pry Tool. When re-attaching screws, do not over-tighten screws
    riz.
    Aug 23, 2007 | Nokia 6288 Cellular Phone
    Audiovox CDM8910US Logo
    159 people viewed this question
    Top Audiovox Cell Phones Experts
    svicari124
    svicari124
    Level 1 Expert
    Computer Repairing
    Computer Repairing
    Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
