I have a rca tv, chassis ctc169. The set doesn't always power up. When it does set works fine.When set is turned off, a 1" horizontal line appears. When the power button is pressed again the set will either come back on or go off.
  • 8,617 Answers
Check for solder cracks around the flyback and around the Horizontal output Transistor, as that chassis is famous for bad solder joints.
Posted on Jun 29, 2008
Rca rear proj. 1993 model p46151wk tv just went dead no picture no sound no light on power button I only found 1 fuse it is good
Take a look at CR4118, and the capacitors around the power supply regulator chip. You likely have capacitors that are dried out. They can take out the chip, and Q4101, the 'chopper'.
The web site: http://eserivceinfo.com/ has a program for the CTC169 series of RCA projo's that is very useful in finding the fault that causes the condition you describe. Just enter ctc169 into the search box. Or go to this URL:
http://www.eserviceinfo.com/downloadsm/4999/RCA_proscan.html
tom
Feb 25, 2010 | RCA Televison & Video
RCA TV Console
Download User Manuals
PortableMedia.ManualsOnline.com Get Portable TV Instructions RCA Television Try this link it says its free
May 27, 2008 | Televison & Video
RCA model #P52720LV will not power on at all. The person that had it before me said that when you tried to turn it on that the button would light up and then the tv would go off right away. Now it will not...
Hi, thank you for visit fixya.
Do you have a problem with power supply parts.
CTC169 chassis series is a common problem , we have a power supply kit for this set , iclude capacitors,IC ,diode and transistor).
CR4118 need be replace too.
If you need aditional information, please let me know.
Thank you
Dec 05, 2009 | RCA Televison & Video
Set turned off by itself, power light flashes, and then I smelled something electrical. It will not turn on with remote or manually.
HI, thank you for visit fixya.
Two possibles solutions:
1.--Horizontal capacitor is burn or blown.
Need be replace, located beside horizontal transistor ( .0082uf 2kv ).
Clean the aarea on the chassis.
2.-- Transformer fly back is burn, need be replace.
If you will work on this tv or any special technician will work on this tv, request for replace capacitor on power supply. Common problem too.
Any question. let me know ,please.
Thank you.
Dec 04, 2009 | RCA HD56W58 56" HDTV
I just acquired an RCA P46738AT television set made in 1994- 1995. The TV makes a quiet charging noise when it is plugged in but no light on the power button and no power. Not sure what to do about this...
This is a common problem and chassis (CTC169) and it sounds like the HV block is bad. Part# 205064. Caution is required when replacing since High Voltage is present.
Sep 27, 2009 | RCA Televison & Video
Tv wont work
does the power indicator blink? If so how many blinks? also do you hear any sounds when you press power?
Aug 09, 2008 | RCA P52926 52" Rear Projection Television
RCA P52960YX1 power supply dead - can I replace this myself?
Ok, Look, you can do this. Just take care when desolder any electronic part. ( position). mostly in capacitor ( - + location). You can buy a : power supply kit for ctc169 chassis. But maybe don't need replace all parts, just replace 2 small electrolytic capacitor 2.2uf 100v and 39uf 100v and ready...I hope this will help you. Thank you !!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Chasis number
this is same ctc169 check for separated power supply for convergence some times 2 wiress goin from main chassis to convergence board red and black are intermiten check for that but you mention that only show menu. select tv and check for tv signal or video imput if you dont have video you have convergence problem and some thing else
Apr 03, 2008 | RCA P52926 52" Rear Projection Television
RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Nov 30, 2007 | RCA 32F531T 32" TV
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
