I have a waltham tv2600hdv tv. it was working fine then last month it started taking a couple of tries to turn on now it will not turn at all.
4 Suggested Answers
  • 124 Answers
SOURCE: My son's 15in LCD tv
Hi, The problem comes from what we would call a "contaminated circuit board". The board has to be replaced or repaired. Since the Television is less then a year old, I am sure the manufacturer has a 90-day parts and 1-year labor warranty policy. Contact the manufacturer would be the cheapest method of replacing the unit. Thanks, Mike H.
Posted on Nov 01, 2008
SD Tech
  • 14553 Answers
SOURCE: tv worked fine last night. tried to turn on today
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD Tech
Posted on Oct 04, 2009
  • 1030 Answers
SOURCE: I own a 52" d52w26 hdtv monitor last couple of
I see two possiblites your flyback tranformer has failed and with it your horzital output transitor has shorted. most technicians can replace these. IS the spark in the front or back of tv. if it is in the front this is a tube. as a tech i would first identify what compnents are sparking. also this could be a capacitor shorting cause a burnt curcit board
Posted on Nov 02, 2010
Nov 02, 2010 | RCA Televison & Video
Starter does not seem to work (intermitent)
HAVE BATTERY TESTED FIRST BEFORE REPLACING STARTER
Aug 31, 2009 | 2001 Saturn SL
SL1 won't start, just single click, electronics work
Try charging the battery or jumping the car, your alternator could be shot and not charging the battery.
May 12, 2009 | Saturn SL1 Cars & Trucks
HP 190 Cartridge cleaning not lasting
You should apply to service. The Fault is caused by wear-out rakel knife. This device which clean the photo a drum.
Mar 25, 2009 | HP 190 Copier
98 Ford Explorer wont move in reverse or overdrive
Probably low oil pressure in the transmission or worn clutches.
Mar 09, 2017 | 1998 Ford Explorer
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
Picture goes off and on...
Most likely your Cathode Ray Tube or CRT is going bad. That model number reflects an older TV. What you are describing is a fairly common problem for that television. If you bump the TV and it improves or gets worse then you know there may be a short.. Either way, I would recommend that you use our Premium Service or use our online resources to find a repair person near you. Good luck.
Jun 20, 2008 | Sony KV-32V16 TV
Samsung 1080p turns itself off
Probably a bad Inverter board. I have a Dell 32" LCD TV but it has a Samsung Panel inside, found a burnt transformer on the inverter board, Still trying to find a replacement.
My TV comes on for a second then goes black, power still shows on but no picture. 1.5 years old
If you are not a tech person, take it in for service.
Dec 27, 2007 | Samsung HL-R5678W 56" Television
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
