Question about Radio Communications
Getting out, but not recieving well...
I drive a truck for a living, Ive always had a good cb. Recently I just switched trucks that already had 2 antennas set up with all the coax run in it. I put in my cb and I am not recieving any thing farther than a half mile, however I can send for at least 2 or three miles or better. Not sure what to do short of ripping out the coax and putting on new antennas. Any suggestions?
  • stevenperez2 Jul 14, 2008
    I have a galaxy dx-33 hml it has no recieve i did get 1 radio cheak but was very low when the volume is turned up all the way up?Help anyone?
    Brigadier General:
  • 6,966 Answers
Initially pls check the grounding of both the antennas and/or their mounts. Thereafter, an SWR check/reading would also be good as it will not only tell you how efficient your antenna is in transmit but likewise in receive.
Additionally, a two (2) antenna set-up (twin tracker) is directional and therefore would have blind spots on either sides and being on a truck (especially with load/trailer) probably even at the back.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 30, 2008
Power problems power stays on cant transmit or recieve
the power switch is fused shut you need to replace it and also the 5v logic supply regulator has failed perhaps this prob means there is no supply too the PLL and logic
this can all be caused by poor quality cheep power switched employed in every cb ive ever serviced rubbish and cruddy so check for all voltages and when and where you need them work from this
then youll quickly find the issue
Feb 19, 2014 | Connex 3300 240-Channels Base CB Radio
2547 when turn on has a squeel thru the speaker in recieve mode
hi iff you remove the mic does this squeel disapear ,if so i recomend that you open mic casing and check for any lose strands of wire that could be shortening out ive seen this happen so many times with microphones you can get some switch oil and apply sparingly to switch this will also help in the long run ,,,,,goodluck with it
Feb 11, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Hi folks ive got a damn problem getting on live everytime i try to sign in it just says ive got internet connection but cant connect to live fully..... when i do live connection test it says ive got a port...
I was searching the web concerning this problem, and apparently there's a good amount of people dissatisfied with the results from their netgear dgn2000 router when hooked up to Live. You can pick up a pretty good router from Best Buy for under 40 bucks. That sucks that you're ISP and xbox support aren't helping. I usually go past Netgear and shoot for Linksys or D-Link just because I've had good relations with them. Good luck getting back to gaming, man.
Jan 04, 2010 | Microsoft Xbox 360 Console
Cobra 29 ltd classic cb not transmitting
Check the ground. Make sure its grounded well on bare metal. To see if the ground is bad, or not making good connection, disconnect the antenna and turn it on. if it does not power up, that means your ground is bad, and it was grounding only through the antenna.
Make sure not to key up with out the antenna connected.
Dec 24, 2008 | Cobra 29 LTD CB Radio
Rci 2950
I know the recieve adjustments are ( and make sure you adjust in this order )L9,L11,L12,L13,L14,L4,L3,L5,L6.Adjust them for highest recieve you may have to go through them a couple of times.And again do them in the order I gave you.VERY IMPORTANT!!! Good Luck
Oct 18, 2008 | Ranger Communications RCI-6900F-25 CB...
Static restricting RF signal while rolling down the road but stops when i apply the brake or when i slow down to stop or when I am sitting still. I drive a truck for a living which is an international,...
Are you using the factory coax. A lot of Internationals have a terrible setup from the factory, they run the coax into a junction box and run your cb coax and your fm radio out of it. You could be getting bad rf feedback through from the FM radio. I would next try a regular antenna mounting bracket setup with a good stranded center coax with at least a 95% braided shielding. You have been on the right track, most problems like this is a process of elimination. If this doesn't fix the problem, or you already have this setup, please reply on here or email me at:
rollincbmods@yahoo.com
I would be more than happy to assist you with your problem.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 20, 2008 | Connex 3300 240-Channels Base CB Radio
Magnum delta force
Hi, You can obtain these parts at www.rfparts.com. the 1969's are around $5.50 and the 2166 is even cheaper.Good luck. If by some strange twist and you cant get them from the source I recommened , get in touch with me , I run a CB Radio Repair Shop and I do have these parts and will sell them to you but you would probably be better off ordering them from RF Parts.
Aug 18, 2007 | Magnum DeltaForce CB Radio
Cb radio
Hi, A couple of switches and knobs you can check (if present in your rig): 1. auto noise/noise blanker switch - try off position; 2. dynamic squelch control - lower down setting; 3. RF gain - should be at max (clockwise); and 4. Delta Tune - normally should be centered. Hope this works out for you and give you an idea where to start. Good luck and pls post again how things turn up. Kind regards.
Aug 07, 2007 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Radio Communications Logo
88 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
