Sanyo Split System Model KS1211W
I think i am having a problem with the remote control receiver picking up an infrared signal from the remote. Or does this sound like a problem with the remote? Where can i purchase a new infrared receiver if needed.
  • 2 more comments
  • Anonymous Aug 08, 2008
    I am have the same problem. New batteries, and remote still won't turn the unit on and off. The digital display on remote is there. And I see the red light activating on the remote when I hit the on/off button, but the air conditioner won't turn on or off with the remote. Any ideas as to what is wrong?
  • john_adamowi Sep 16, 2008
    I have the same problem the remote reads normal however will not
    turn the unit on and off and the temp is not responding to the remote.
  • Anonymous Sep 27, 2008
    LG split AC wall unit does not turn on, remote display works fine.
  • B96813 May 05, 2009
SOURCE: manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Posted on Sep 06, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
alex_salve
  • 78 Answers
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Posted on May 17, 2009
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
  • 81 Answers
SOURCE: Need to know what the icons stand for on remote
Generally all the symbols on each unit are the same. The snowflake does cooling, the sun does heating, the fan does fan only mode, the water droplet does dehumidify and the arrows means automatic mode. The increasing bars refers to the fan speed.
Mat
Posted on Jul 17, 2009
Why do I now have to be very close to tv for remote to work?
There are a couple of different remote control technologies. Point to point Radio frequency, networked radio frequency and IrDA...or infrared diode.
Your Sanyo GXBM is an IrDA based remote. The diode is a lot like a lamp, only the signal it sends would be easier sensed by people as a change in temperature if it were strong enough.
Over time, the IrDA LED can degrade and will eventually fail. The transmitter in the remote can also fall out of spec over time, and the remote receiver in the TV lose its tune to the specific frequency that the remote broadcasts, making it harder to 'hear' he remote commands.
Other common issues for losing the range you had when it was new is clouding or scratching of either of the protective lenses on the TV and the remote.
i have included a direct replacement part for your GXBM
SANYO GXBC TV Remote Control
Sep 04, 2015 | Sanyo GXBM Remote Control
I havea 46" sanyo model dp46841 lcd tv but the tv wont respond to the oem remote or universal remotes ?
Sounds like the infra-red sensor inside it is either damaged or it do not get proper voltage to work. Check it. If it get proper voltage/s and still not receive any infra-red signal from the remote control, replace it. The part in discussion will look somewhat like this.
25758228-54zq5khwu0nuxgxnhh2yrt4a-2-2.jpg Prior the replace this component, make sure that the remote control you're using works properly, and do emits infrared light rays, during each button presses on it. Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jun 23, 2015 | Sanyo Televison & Video
I have had several technicians at my parents house they have a sanyo pdp42xr9da with remote rcj17oa the remote dosent talk to tv we have had the tv for two years it did work but now dosent please suggest...
Most of the fault in this kind of symptoms is the remote control itself.
To confirm it, aim directly the remote control to your cellphone camera and press any button key at the remote control. While pressing the button key, you will be able to see the flash of the infrared indicating that the remote control is working fine. If you can't see the flash of the infrared this is an indication that the remote control is already faulty.
Remote control
If you've confirmed that the remote control is working fine, then the fault came from the infrared receiver(sensor) of your tv. It needs to check by the qualified technician to isolate the problem.
Feel free to ask question of you need further assistance.
mjsazon
Oct 04, 2011 | Televison & Video
My Bose V30 system with the RCV1T-27 remote wont send the IR signal to my Motorola DCT 6416 if im not standing right in front of the Bose display unit. The light on the display still blinks as if its...
Hello
Check the cells in the battery compartment of your remote control handset. Replace it with new ones and check. Still you poise this problem, the intensity of infrared rays come from your remote control, or the sensitivity of the infrared sensor inside your bose front panel system may have the trouble. Just replace the infrared LED of your remote control with an other one of same type. If it does not helps you, repalcing the infrared sensor will reftify your problem. OK.
May 05, 2011 | Bose Lifestyle V30 Home Theater System -...
My Tv Remote GXDB DOESNT WORK ANYMORE HOW DO I GET A NEW ONE I PUT IN NEW BATTERYS AND STILL DOESNT WORK tv is only a year old
Please look here:
http://www.google.com/search?q=sanyo+gxdb+remote&hl=en&rlz=1T4GGIH_enUS282US283&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yClfTdL3EI2osQPE8dDPCA&ved=0CC0QrQQ
Or Google 'SANYO GXDB remote"
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
Please leave rating if it helps.
Feb 19, 2011 | Sanyo DP50747 50 in. Plasma TV
Sanyo sap-71a will not start using remote the remote will start other air conditioners thanks
Simple, remove power and then unplug DC wire from indoor display for 2 minutes.Again plug it, power on. And also remove batteries and re insert in remote and then use. If still problem, your signal receiving sensor defective. You have to repair/replace indoor PCB.
Feb 05, 2011 | Sanyo 12KHS71 Split System Air Conditioner
May 17, 2009 | Heating & Cooling
TV Remote Control Symbols.
Sorry, I have NOT asked for assistance on a Sanyo air conditioner. But I have asked about standard symbols on remote controls and not received any replies yet.
Tony.
Nov 25, 2008 | Sanyo 24KS32A Cool Mini Split Air...
Infrared signal
Inside the tv on the power board there are two ribbon like connectors which stretch across to the main board. I would say that one or both of them have become uncoupled.
Jan 25, 2008 | Sanyo DS27910 27" TV
Infrared receiver
On page 14 of the Manual, it shows a diagram of your receiver. The infrared receiver is number 44, labeled "Remote Control Signal Sensor"
Dec 31, 2007 | Panasonic SC-HT690 System
Heating & Cooling Logo
321 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
