Back to:
Tags:
D-Link Wireless Router
Cannot aquire IP address through my Desktop using...
posted by hekpdesk on Jun 29, 2008
My desktop seems to get hung up in the "renewing your IP address" function when I do a "repair connection" operation. I have re-booted both the modem and the router and It can easily aquire the ip address through the other two laptops I have, but not through the desktop.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 29, 2008
Thanks for Trying (70)
mahjid
Rank:Wiz Wiz
Rating: 85%, 23 votes
what you do is to reboot your desktop and everything will be fine or either unplug or disable and enable the status of the connestion. But the best way is to reboot the system. Good luck
Rating Locked! (?) hekpdesk has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cannot aquire IP address through my Desktop using Lynksis Wireless Router:
I don't want to Accept this solution
Can you Help with these Routers problems?
Routers
have 1 laptop and wan to use wireless
Routers
attempting to connect a printer to the wireless system....
Routers
I have two laps with same config, brand and VISTA home...
Routers
after u save thr running configuration at...
Routers
i tried portforwarding using portforward.com guide. but...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
