Frigidaire FAC107P1A2 Hello Maanita, I was able to determine that the outlet is working (110V) and that there is current running through the power cord. But the unit still does power on.
    Genius:
  • 1,142 Answers
Then you need to check if the power supply is actually getting the power or not,,,, may be the capacitor needs a replacement.
Posted on Jun 30, 2008
What do i have to do to plug my 110 air conditioner into where my 220 window unit
You need a step down transformer, to convert 220V to 110V. You can't just plug the 110V A/C unit in directly unless it is clearly marked as being suitable for multi-voltage supply (110V - 220V input).
Such a transformer has to be of sufficient capacity to handle the current, or wattage, that will be required. The Frigidaire unit in your question is a 3.5 kW cooling capacity, so the transformer would need to be about the same, ie for a 10A supply at least. They are quite big boxes, about $120.
http://welectronics.com/TRANSFORMERS/step-up-down.JPG
You would put this in the roof or in a cupboard.
Apr 25, 2015 | Frigidaire FAC126P1 wall/window Air...
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
I have 230V AC units and a 110V Condensate pumps can I hook up a power feed from anything inside or around the unit? A 110V wall socket mains feed is not close by.
Just return the condesation pump and get a 208/230 V one. Thats the only 100% correct way to do that. I know people in the field who have tapped off one leg of 230 v and run neutral to the casing and the unit will work but it isnt recommended. Your not supposed to run a current carrying conductor to the casing but its up to you. If this helps please rate me and do a testimonial.
May 25, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
230V FEDDERS I HAVE 110V AND 20AMPS COMBINE HOW MANY AMPS DOES 230V NEEDS
I give simple formula to determine amps:
I (amps or current) =watts/volts.
And with above formula,you can calculate volts and watts too.
Helpful?
Jan 05, 2011 | Friedrich X-Star XQ10L10 20" Air...
We just bought a frigidaire 22000 btu unit. We we
If you have or know someone how has a multi meter just test that you have 220 volts at the outlet. Thats about the only way to tell. The fan will run if you only have 120v at the outlet, just not the compressor. so it will not cool. If you only 120v at the outlet it could be just a fuse or breaker problem. If it's a new outlet then it could be wiring wrong also.
Hope this help
Dan
May 22, 2010 | Frigidaire Heating & Cooling
Hi, my Frigidaire AC (FAA068P7A) unit was working fine last year. Put it back in the window today and now it won't power on. I checked the power cord, but cord is fine (I actually opened up the machine...
Sounds like a breaker has tripped (caused by the unit) or is it might just be 'off' for some reason. I would check the outlet (where the AC plugs in at).
If the AC is a 110V unit you can check the outlet by plugging in something else, i.e. a hairdryer. If the hairdryer doesn't work either - then you know your breaker is tripped. On the other hand if the hairdryer 'works' then you know the problem is in the unit, where I'm afraid you'd be better off to have a technician to trouble-shoot it, although you could try sending additional information at this point for more help.
Remember if it is a breaker tripped - it was probably tripped by a malfunctioning Air Conditioner so if it 'trips' again in the immediate future you will need someone to check it out.
good luck!
May 03, 2010 | Frigidaire FAA068P7A Air Conditioner
No power
Could be some kind of fuse it the unit.
Aug 17, 2009 | Frigidaire FAC107P1A Wall/Window Air...
then there is some wiring that has bee damaged sir.
you can open the unit and start investigating about this problem.
but do it only if you have prior experience
dont forget to accept the solution sir.
thank you
Jun 29, 2008 | Heating & Cooling
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
