Question about HP Photosmart C7280 Printer
Wont send fax
I get an error 350 everytime i send a fax
  • celltecairco Jul 28, 2008
    C7280 will print documents from various programs, can send faxes if I dial manually. But every time I try to send a fax from the print menu using the drop down menu and chosing "Hp photosmal C7200 series fax" the unit dials the number, you hear it connect and start to fax but then it stops and says fax failed. At this point the solution centre then states the hp printer is offline and after I unplug and re-plug the usb cable in it then says its back on line. It has done this from the moment it was installed last week (brand new unit). I don't want to waste paper by printing the fax and then having to manually fax it. Please help hp support to date are no help at all
    Thanks
    Anne
    Novelist:
  • 106 Answers
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
2 Suggested Answers
Khalsa007
  • 79 Answers
SOURCE: hp photosmart 2610
HI,
u can try to reset the printer.
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
Posted on May 29, 2008
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
With my epson 520 i can recieve faxes but i can't send them.. everytime i send one it says no answer but i verify that the fax line im sending it to does work.
Hey I had this issue as well with my FAX and I validated that my setting were good and I'd even hear the Fax line pick-up and get a "no Answer" error. I went into FAX settings and just turned something called TCM off and then it worked. Maybe it is for sending it to an older Fax machine, but I did get it to work!
Dec 05, 2010 | Epson Stylus Multifunction Printer/...
I have an hp officejet pro 8500 fax, scanner, copier and printer. I keep getting an error message 350 when I have repeatedly tried to send a fax. What do I do and what does error 350 mean? Thanks in...
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
Sep 12, 2010 | Computers & Internet
Everytime I send a fax from my samsung sf 370 i get
It can be the other person's fax or there is something wrong with your lines. Conect fax to another line then try again.
Oct 01, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
C7280 fax error code 232
They might be trying to send from a DSL phone line.
Aug 18, 2009 | Office Equipment & Supplies
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Error 350
Error 350 means...
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Try this solution...
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved. (To turn off the ECM, simply press the setup button on the pritner, use the right arrow and select advance fax setup on the options. Press ok under advance fax setup. Use the right arrow and select Error Correction Mode. Press ok and select Off.)
*Try sending at a lower transmission speed. (To lower the transmission speed. Press the setup button, go to advance fax setup. under advance fax setup, look for Fax speed. change the fax speed to slow)
After you have done the T/S, try sending a fax again.
Hope this would resolved your issue.
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Samsung SF350 Fax
Verify that you have a dial-tone with a phone plugged into the wall jack.
Aug 26, 2008 | Samsung SF-350 Plain Paper Inkjet Fax
Sending fax
Try turning off ecm (Error Correction Mode) It appears this may be common on this series. Basically line issues
Feb 15, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
HP Photosmart C7280 Printer Logo
674 people viewed this question
Ben Johnson
