Question about JVC Televison & Video
How can I program taping of programs on the JVC HR-XVC27?
  • Dustin Ellse
    Dustin Ellse May 11, 2010
    I gave you a link to a manual that you asked for. Here is a copy of our chat:
    BearWeb:
    Welcome to FixYa Live Support, how can i help you?
    Lb14:
    Hi BearWeb,
    Lb14:
    I lost the directions as to how to tape programs with my JVC HR-XVC17. Can you give me directions?
    Read more
    BearWeb:
    Yes i can, please just give me a minute to search my database.
    Lb14:
    Is there a problem with the model # I gave you?
    BearWeb:
    Are you still there?
    Lb14:
    Yes I'm here.
    BearWeb:
    Sorry, my computer hung for a second, i am back, what is the make and model of your DVD player?
    Lb14:
    It is JVC HR-XVC17 and it has SQPB also, hope it helps.
    BearWeb:
    Ok thanks.
    BearWeb:
    Would you like a link to the user manual?
    Lb14:
    Yes please!
    BearWeb:
    I have downloaded manuals from Retrevo before and i find them very helpful, here is the link:
    BearWeb:
    http://www.retrevo.com/support/JVC-HR-XV...
    Lb14:
    Ok, hope this works.
    BearWeb:
    Have you clicked on the link yet?
    BearWeb:
    Thank you for using FixYa. Have a nice day and please remember to give this conversation a good rating.
    After you did not reply any longer i had no choice but to leave.
  • Dustin Ellse
    Thank you for using FixYa, please remember to give our earlier conversation a good rating as i did help you. I will appreciate it, thanks!
The solution that BearWeb gave me after trying to find the information in his or her data file was to give me a web sight in which to find the information.
Posted on Jul 01, 2008
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
My JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
my JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
Dec 24, 2009 | JVC HR-DVS3 Mini DV/S-VHS VCR
I just got a JVC HR-S3500, The online manual only gives timed recording instructions for the number code on a program listing. I need to know how to record by time and channel. This was simple with my...
To program the recording by time and channel, press Prog then press Start +/- (the left-most +/- button below the number pads). You should see the time and channel blanks. Continue pressing the Start +/- button until you get to the desired start time. If you press and hold the Start +/- button, the time will advance by 30 minutes. To set the Stop time, press the next button to the right (the Stop +/- button) until you reach the desired end time. Use the next toggle button (to the right) to set the Date for the recording. Use the Channel +/- button (the right-most button in the row) to set the channel to record. Set the tape speed with the SP/EP button below the Date toggle. Then press Prog or OK to save the recording. This is in the manual under Express Timer Recording which starts on page 42 of the manual. I found the manual here: http://resources.jvc.com/Resources/00/00/99/LPT0024-001B.pdf .
I hope this helps.
Dec 19, 2017 | JVC HR-S3500 S-VHS VCR
JVC HR-vp673U
Be sure no foreign object is in the tape well. The other possibility is that the carriage assembly needs work...accordianman
May 11, 2008 | JVC HR-VP673 VHS VCR
JVC HR-DVS3U -- time code issue
I Have the same problem. It will cost me $350.00 plus tax to fix.
Aug 24, 2007 | JVC HR-DVS3 Mini DV/S-VHS VCR
Televison & Video Logo
19 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
