Question about Tacsew T500
Tacsew 146 RB zig zag/walking foot
Hi , I have a TACSEW T146RB WALKING FOOT ZIG ZAG and need some help please. It will sew ahead Fine in all width and length cominations , But when I go in reverse it leaves loops on the bottom side, always. Do you have any ideals what is the problem? Thank You Harris Jones
  • 749 Answers
SOURCE: Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Posted on Nov 17, 2007
SOURCE: Tacsew T500 : Needle continually comes unthreaded
No this machine does not use a bobbin. I just purchased one too and called the supplier to help me keep mine threaded. He said they do not take much tension at all. So check your tension and then when threading it, make sure your thread goes under the bar in the center of the tension disk, not on top of.
Good luck, once you get it going it does a beautiful job!!!! Love it, Love it!
Posted on Jan 28, 2008
riclap
  • 3 Answers
SOURCE: tacsew lu-563 sewing machine
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Posted on Jan 01, 2009
  • 108 Answers
SOURCE: need a manual for my tacsew 20u43 sewing machine.
try at www.ifixmachines.com
Posted on Feb 15, 2010
  • 1116 Answers
SOURCE: where can i download a tacsew t111 155 manual
I could not find a download, but found this company has a manual - http://www.allbrands.com/products/abp07642-1204.html
Posted on Feb 24, 2010
DOES THE TACSEW T1718 MACHINE SEW IN A ZIG ZAG
Does it have a Stitch Width control? If not, it is probably a limited stitch only. Most Tacsew machines are made for high speed industrial sewing and frequently are made to perform a limited number of stitches. It appears this is a blindstitch for hemming.
Tacsew T1718 4 Full Size BlindStitch Hemmer Machine 1718 TAIWAN 8mmLift 3...
TACSEW T1718 YouTube
Oct 26, 2016 | Tacsew Sewing Machines
Cant get tension correct when zig zag on really strechy material
Be sure you are using a ball-point needle. Try setting the upper tension looser. You also may need to increase the presser foot pressure on your machine (consult your owner's manual if you don't know how to do this). Using a closed-toe presser foot (vs an open-toe embroidery foot) may help control the fabric and prevent it from puckering under the needle. Also, reducing the width of the zig-zag may be helpful.
Some sewing machines have an overlock presser foot. Effectively, there is a thin piece of metal in the center of the presser foot. The needle will straddle that piece of metal in a zig-zag so the upper thread has a little bit of slack in each stitch that will let the fabric lie flat. It is a very nice tool to have especially when zig-zag finishing raw edges too.
https://www.amazon.com/Janome-Top-Load-Overedge-Foot-Brush/dp/B00KCWB2SA
C9store overlock presser foot how to video
Some sewists will increase the fabric's "body" by inserting a layer of wash-away or tear-away stabilizer. If it is only a small project, a piece of paper added to the seam (like adding machine paper) will help stabilize the fabric.
One last thing to try would be loosening the bobbin tension. However, there is a reason it is the last effort, because most sewists are uncertain about messing with the bobbin and it is also requires "minute" adjustments to effect a big change.
How can properly adjust my tension
Understanding Bobbin Tension
Jun 18, 2016 | Sewing Machines
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
Dec 03, 2015 | Bernina Sewing Machines
Viking lily 545
You can bend the arm on the walking foot a tiny bit to the left, then turn the machine by hand to see if it stays on, bend a tiny bit more and repeat.
May 13, 2014 | Sewing Machines
I have a Brother CS6000i sewin machine and I'm
Mmmm Are you using the right stitch? Like zig zag or straight stitch only with a medium stitch length? Check that and test again.
Sep 06, 2012 | Sewing Machines
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
Is pico edging possible in this machine
Yes, just adjust your width of your zig zag, and pattern. Practice on a scrap piece of your material for the look that you want. It is easier with a hemming foot but a zig zag foot will do just fine. Remember picot means "roosters beak". Good luck and have fun with it.
Sep 18, 2010 | Singer 8280 Mechanical Sewing Machine
Tacsew T500 Logo
106 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
Shehu Pro
Shehu Pro
Nick Olsen
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
