Question about Bose Lifestyle 28 System
Dvd player when using dvd player movie only shows in black & white, not color
  • 2 more comments
  • landaiche Jun 29, 2008
    I need additionl help. Where exactly do I find this setting ntsc/pal
    the tv is Mitsubishi WD65731
    bose lifestyle 28 surround sound 5 2 1 with dvd player
    all connections are good. System has been in place 18 months and has not been moved. recent power outage may have been cause.
  • landaiche Jun 30, 2008
    no I purchased this dvd. I do not pirate dvds. There must be some setting that is off, but I do not possess the knowledge to correct it. I will have to call someone out to service the device.
  • 1,879 Answers
Greetings,
Locate your manuals and make sure all equipments are using NTSC color system. Check the DVD too if it is for NTSC.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 29, 2008
    President:
  • 1,257 Answers
You will find a button for ntsc/pal at your remote of dvd player..change it to ntsc or pal colur system..
You may also have this color setting on your tv remote..........
let me know if this works
good luck
D.I.L.I.P
    Guru:
  • 1,894 Answers
Change the NTSC/PAL setting in your player to auto
  • dewan nafees ahmed Jun 29, 2008
    in the video settings of your DVD player.
    and i can bet on one thing.
    this happens because the DVD player is not compatible with your TVs company.
    i don't mean it wont play any disks.
    but you wont get proper color on many DVDs.
    i had the same problem with my player. at last i got fed up and changed my DVD player and bought a Moser baers player.
    now change the settings and see if you get color for VCDs at least.
    u can find the compatibility list in your manual of your DVD player.
Are you using the S-Video to Component converter? I was having an almost identical problem, the picture wasn't b/w, but would get a red 'haze' for color.
If you did hook up your Bose to your TV via component, go to the DVD Settings, and enter the System Setup. Scroll down to the 'More'...button and one more time to get to page 3 of 3. Change the Video Output to YPbPr.
Posted on Jul 07, 2008
  • 6,487 Answers
Did you hook this set up to a differant TV set, differant from the one you first got this unit? Before condemming the unit, make sure the unit is not in progressive scan, unless of course the TV set is compatible with those types of signals. There should be a progressive scan button on the remote. Look in the instruction book for info on that if your not sure.
Hope that helps...........
    President:
  • 1,944 Answers
Is your TV multisystem?
  • 796 Answers
If you are using pirated cd/dvd on the player there are chances of getting colourless images.......
  • 758 Answers
What connector did you use to hook it up with? S-Video (single circular connector), Composite Video (single RCA connector) or Component video (three RCA connectors) ?Check all the cables, my system sometimes does this when the leads are loose
I hope that helps
Thank you
Computerrep
    Brigadier General:
  • 3,614 Answers
May i know the TV set model that you have, and also the exact model of your dvd..
Kindly please check the unit video system first/
2 Suggested Answers
  • 71 Answers
SOURCE: black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Posted on Mar 15, 2009
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
Our dvd player now only works showing movies in black and white. What can we do? It use in color but for some unknown reason the movies are in black and white.
someone must have pressed something mistakenly.
Check the DVD remote and press PAL/NTSC. The color should appear.
Or you could also check the video wire at the back of the DVD and TV, maybe it has loosed contact.
I wish you all the best.
Jan 07, 2010 | Toshiba SD-2800 DVD Player
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Dvd player not showing color
you are only having porblem with your color system. if you are using a multi system DVD player then see if it is properly selected to your region. in USA it should be NTSC 3.59, if you're in Europe it should be PAL. if you're using your DVD via a DSP or audio systems, check also the color system of the amplifier, it should be adjusted to your color system.
Mar 31, 2008 | Aspire Digital AD-900 DVD Player
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
DVDs are only in black and white
Jimbo.. is your new TV HD compatiable??
Nov 11, 2007 | Apex Digital AD-1110W DVD Player
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Bose Lifestyle 28 System Logo
466 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
